Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Win)
Old 04-29-2014, 10:32 PM
flako15 flako15 is offline
Default Pro tools 10 and M-audio Fast track pro
so ive been stuck trynna figure out why theres no sound playing from pro tools i changed the buffer size and updated the driver still nothing, i need help
Old 05-05-2014, 08:31 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Pro tools 10 and M-audio Fast track pro
Hi, Start here:
Help us Help You - READ THIS Before Posting!
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2018.12
Old 05-05-2014, 09:28 PM
zedhed's Avatar
zedhed zedhed is offline
Assuming you have the latest/correct fastrack driver installed;
Go into Pro Tools/Setup/Playback Engine and make sure fastrack is selected as playback engine.
Then go into Pro Tools/Setup/I/O Setup and on each of the input,Output tabs click 'default'
Make sure your I/O routing's are set correctly on the channel strip in the mix window.
If this doesn't work, more info will be needed as per above post.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Using M-Audio Fast Track 8R with Pro Tools 8 LE drjordan Tips & Tricks 3 12-19-2012 01:20 AM
M-Audio Fast Track / M-Audio Venom in Pro Tools 10 leinad MIDI 1 09-16-2012 10:13 PM
Using M-Audio Fast Track Pro With Pro Tools HD???? hemiloco915 Pro Tools TDM Systems (Mac) 11 04-30-2009 10:11 AM
M-Audio Fast Track Pro and Pro Tools LE Pete Seizure General Discussion 1 02-27-2009 05:53 PM
Pro Tools & M-audio fast track vreynoldsv Pro Tools M-Powered (Win) 3 12-19-2006 01:56 AM
