Old 11-30-2006, 01:07 PM
KenSluiter KenSluiter is offline
Default \"purge\" entire session of automation at once?
I'm re-doing/fine-tuning my template before my next project.
Somewhere down the line, I changed the timecode "session start time", and that seemed to leave a breakpoint on ALL possible automate-able lines.
I have to view every volume, send, pan, plug in parameter etc. all manually delete these "breakpoints"
Can I simply "purge" an entire session of all breakpoints/automation at once?
As always, thanks in advance.
Ken Sluiter
Old 11-30-2006, 01:20 PM
Drew Mazurek's Avatar
Default Re: \"purge\" entire session of automation at once?
select the ALL group, make sure you select the entire session including any breakpoints that may be far out. Select Edit/Clear Special/All Automation.
www.drewmazurek.com
Old 11-30-2006, 01:23 PM
where is "clear special"?
Old 11-30-2006, 01:50 PM
Edit Menu
www.drewmazurek.com
Old 11-30-2006, 01:54 PM
Crazy!
I don't have that option in my edit menu.
Old 11-30-2006, 07:15 PM
francois francois is offline
looking at your 2 post,you might want to update to PT 7.2
PT 2018.4 -HDX1- OSX 10.14.5-MacPro 12 core 3.46
64 Gig ram- D-command 24-Trinnov Dmon
Moving Entire session over DAMNBABY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-06-2012 03:43 PM
Undo mute automation in entire session danielmak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-17-2009 09:06 PM
Burning Entire Session onto DVD? philbowden 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-14-2006 05:21 PM
Downsampling entire session: Should I? AceZero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-24-2005 05:44 PM
Best way to dither an entire 24/96 session to 48k spong Pro Tools TDM Systems (Mac) 3 02-25-2002 05:36 PM
