Best cd burning program
Hi all, what are your recommendations for burning cd mixes etc.? My burner came with nero, invasive POS that it is. I am after just a good simple burning program.Cheers Mick!
Re: Best cd burning program
CD architect works great...does red book and all that good stuff
003r/i7-930/LE 8.0.1 cs2 on xp |
WaveLab here and I believe they make a version called WaveLab Essentials that is much less money.
.... and then there is this .... http://infrarecorder.sourceforge.net/
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
How do you listen to files in CD Architect? Through your Digidesign hardware?
Thanks,
Once PT is closed you should be able to.
Yeah....it doesn't run through the digi drivers and protools....but critical listening/tweaking should be complete by the time you're burning to CD.
I know Pro Tools has to be closed, it's only single client.
I noticed that CD Architect allows trimming and cross fading. I was only going to use it to make some playlist CD's for the car. I just wondered if it played through the WaveDriver or ASIO driver so I could hear the playout on my nearfields. Guess not. Thanks,
CD Architect will play back through the wave driver, but not ASIO. CD Architect is quite a bit more than just a burning program. It really impinges on being a mastering application. At this point it will only use DirectX plug-ins but Sony gives you quite a few with CDA. You line your tracks up on a timeline in whatever order you want, adjust the lengths, add fades, adjust volumes of each track via envelopes (very similar to PT edit window automation). You can add any DX plug-in to any individual track to adjust EQ, or just about anything you want. These tracks also go to a master bus where you can add more Plug-ins, dither, etc. You can do hidden tracks, get around redbook specs if you want, eliminate time between tracks, etc. I think you might get CDA free if you buy Soundforge 9 which also comes with additional DX editing/mastering plug-ins.
Hope this helps, Greg |
Whats the best CD Burning program *DELETED* | liquid002rw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 12-22-2004 08:31 AM |
What CD Burning Program to Use ? | Dutchmuzik | Pro Tools TDM Systems (Mac) | 21 | 08-01-2003 02:56 PM |
What CD burning Program with HD? | Hardnox | Pro Tools TDM Systems (Mac) | 8 | 12-22-2002 01:30 PM |
Best CD Burning program? | rope | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 06-25-2002 07:40 AM |
no cd burning program!!! | cmink | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-14-2000 12:02 AM |
