Parallel Compression in the box.
Hi - I'm trying to use parallel compression within my TDM system when mixing in the box , but experience phasing. Is there any way around this? Thanks in advance.
Re: Parallel Compression in the box.
If you're on a Mix system you'll have to set up Aux busses, and then compensate for the dealy manually. I can tell you how to do it, but I'll wait to see what hardware you're using because it's a lot of typing... Steve
Steve Shepherd Extreme Mixing |
There is a delay compensation plug-in can be inserted on the track without compression, and delay the track by the number of sample delays that the processed track is showing. When doing parallel compression, I usually just have the same compressor on both tracks, because I still lightly compress the first track and squash the second, and the delay will match.
Thanks for the advice - I'm using HD Accel with a 192 interface , any more advice would be great!! Many thanks. |
Hi.
It would help if you posted PT version, and exactly what you're doing that causes phasing. I do this all the time ITB, and with outboard units. Works very well for me. I simply choose short or long delay compensation in the Playback engine, make sure ADC is enabled (Options) and off I go.
I'm using 6.92 - I'm going to try delay compensation - and let you know how I get on.. Thanks!
I'm running PT7 LE, so that would realy help me!! can tell me where to get this from, cos i can't find anything on google |
You searched too far… you already have it (part of the standard complement of ProTools plug-ins). See your documentation for what’s what.
PS: This is the PT TDM forum. Please note that there is a forum dedicated to ProTools LE (scroll down from from the DUC’s main page and you’ll see it). While most of the PT software is the same for both platforms, each has its own set of exclusive features, issues and problems. Therefore, most answers to such will vary also—highlighting the wisdom of posting on the appropriate forum. IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
Funny, I just mixed a track last night and started playing with parallel compression on the lead vocal. It just felt a little thin and I wanted to beef it up. Firstly, I have delay compensation turned on for the session, that'll prevent any phasing. Then I added a send on the lead vocal track and sent it to bus-16. Then I setup a mono-aux and set the input to bus-16. I compressed the crap outta that aux, also rolled off a little of the bottom end on EQ, and mixed it in to taste. Sounds wonderful! Really adds body (a little vocal Pantene).
Is that the recommended way to do it in PT? I like the results, but want to make sure there isn't a better way... --> freddie ____________________________ Freddie Feldman VOCOMOTION A Cappella Recording Studio www.vocomotion.com www.DarkSideVoices.com www.TheThumper.com |
Parallel Compression Routing | Mack Truck | macOS | 10 | 02-06-2012 08:41 PM |
parallel compression sends? | Khatru | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-15-2009 08:58 AM |
Parallel Drum Compression | soundboy35 | Pro Tools TDM Systems (Mac) | 6 | 06-02-2009 11:42 AM |
Parallel Compression? | SoundguyJP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-28-2006 06:38 PM |
Parallel compression and 6.4 | Aquarius | Tips & Tricks | 2 | 07-05-2004 03:05 AM |
