Pops and Clicks during playback
I am running a PT 5.3.1, 192 I/O, Mac G4 notebook PCI, OS 9.2, Studiomixer24, w/expansion chassis.
I tracked about 15 tracks@ 24bit, 48k simultaniously onto Data Express FW connected drives during a live preformance. The Recording captured without any incident. No peaks appear in the edit waves. When I play the tracks back, audible clicks and pops appear on the meters and in my monitors. I have tried to adjust the DAE buffer size, as well as resetting different CPU usage sizes. Nothing is working!!!!! PLEASE PLEASE HELP!!!! Thanks Rob. |
Re: Pops and Clicks during playback
Have you made any changes to the sample rate or bit-depth?
soundphaRm |
Do you have any 3rd party firewire drivers installed? If so, remove them, and only use the Apple firewire drivers that came with OS 9.2.2
I am not familiar with your audio drives, are they compatible according to the digi specs? i.e. 7200rpm, Oxford 911 chipset, formatted using Apple erase disk (according to Digi instructions in the Firewire compatibility docs)? Are the pops and clicks random or are they happenning at the same place every time? [img]images/icons/confused.gif[/img]
Karen Basset Boom Chic Studios Los Angeles, CA 90048 [email protected] http://www.boomchic.com |
The pops and clicks are random. They appear in different spots, on different tracks during each play. Sounds almost like an old LP. |
Those are read errors.. don't do anything to the drive.. no utilities - as the read errors could be rewritten to make them permanent.. Try using the Finder to copy the session to another drive (how about SCSI) and see how it plays back from that.
Rail
how did u track them , i can remember having pops and clicks by recording f.ex dat to pt without setting pt to slave . ( clocking problems ) ???
maybe [img]images/icons/confused.gif[/img] |
Chris
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.6.4 Monterey -32 gigs Ram - Carbon - Protools 2024.3 Ultimate |
Chris<hr /></blockquote><font size="2" face="Verdana, Arial">Hmm... it's always random if you have clocking problems... -Robert
www.extensivemusic.com |
if u have recorded it using a " wrong " clock your fu**** . theres no way to fix it . the audio files wont synchronize right , and pops and clicks will occure ( it sounds like random , but it isnt [ whyever ??? cant explain but had my experiences with it [img]images/icons/mad.gif[/img] ] ). i hope thats not the case . you cant fix it by trashing the prefs . the sync is recorded in the files . the clicks and pops occure when running out of sync .
hopefuly not , good luck |
Pops and clicks in playback- SOLVED!!...really | zedman | Pro Tools SE and Essential (Win) | 4 | 06-23-2013 02:02 PM |
Clicks & Pops on playback | mikevarela | Post - Surround - Video | 11 | 12-01-2010 03:20 PM |
Pops and Clicks in playback | photomatt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 04-27-2010 12:41 PM |
Pops and clicks during playback | mydog_norm | Post - Surround - Video | 1 | 07-30-2006 10:18 PM |
clicks and pops.. playback help | zunam666 | Pro Tools TDM Systems (Mac) | 4 | 05-27-2006 01:23 PM |
