Ok so last week i finally caved in and pulled away from logic and decided to take the big plunge into pro tools
![]() So i go online and buy the 003 rack interface with the factory bundle, That has two Firewire 400 outputs on it. and with it i purchased the new- iMac 27inch 2.8GHz Quad-Core Intel Core i7 with 4GB 1066MHz DDR3 SDRAM and 1TB Serial ATA Drive Alas in this lies my problem This new computer only comes with ONE, I repeat ONE Firewire800 port. So I figure, "okay i'll just buy a Firewire 400 to 800 converter cable" which I did. In this lies another problem, Pro Tools recommends that i use an external hard drive with speed of 7200 rpm and uses Firewire 800. But I CAN NOT FIND A FIREWIRE 800 HUB! so what do I do?!?!? The only solution i can think of is: -Buy a regular Firewire 400 hub -Use the Firewire 400 to 800 converter to connect that hub to my new imac -Connect the 003 rack into the hub -And connect external hard drive to hub at old firewire 400 speed ![]() Do you think this will work??? ![]() should i just connect the external hard drive to my imac with a usb 2.0??? please please please help me, I BEG OF YOUUUUUUUUUUUU ![]() |
Hello JohnPaul; Welcome to the DUC where searching will get u over hills & mountains
![]() pretty simple actually;Computer to Hard drive>Hard drive to rack via 400-800 cable(or 800-400/whichever way u wanna view it)... the not so simple part will be SL & PT (Snow Leopard & Pro tools)
MYSPACE ON'EIM LAUTEN MICS & ME DA'TUBE ON'EIM 'IS TAMARA HOME' ![]() NO, SHE'S WITH HOBO KEY ' ![]() ('we' must start using pronouns) |
ok soo what you're saying is
connect an external hard-drive into the firewire800 port on my imac, then connect the 003 rack directly into that external hard drive?? that will really work?? on the snow lep and pro tools note, im hoping that Pro Tools 8.0.3 pre-release will do it for me |
oh and the reason why i didnt search is well...
i had no idea what to specifically search for haha, im new to protools so i feel 100percent overwhelmed and thanks for the quick response too greatly appreciated ![]() ![]() ![]() |
![]() Quote:
I might also recommend getting an esata card for your new mac such as this one: http://www.sonnettech.com/product/tempo_sata_e2p.html
Frees up the load on your FW bus and it's a lot faster for large file transfers etc.
IMDB |
Hey Norad, u may wanna check around & suggest that in some other threads because there are quite a few guys who worry about this due to imac's shorts & I don't think many know about the card...jus sayin
I too ha djust purchased the Digi003, but mines the interface (mixer). I also have a iMac with one 800 port. The connection stated above is actually in the manual it says that if your mac only has 1 FW port, connect the Digi003 to the back of an External HD that is connected to your computer. This is my configuration;
iMac -->FW800 cable-->FW800 500gig Drive-->FW800 cable--->FW800 250gig drive ---->FW400 cable to interface. My hard drives only have 2 FW800 and 1 FW400 ports, so I connected the drives to the iMac with FW800, then used the only FW400 connection on the drive out to the Digi003. This has been working very well. Also if you havent already done so, pick up a good ext FW drive. USB drives are not supported.
iMac 24" 2.9 Ghz 4gig RAM, OS Leopard 10.5.6, Digi 003 Factory Interface Protools LE 8, Glyph 500gig Audio Drive, Glyph 250gig Samples Drive |
Norad,
You mentioned the sata card, but it looks like it's just for pci slots on a mac pro. Is there something for Imac that I don't know about? The OP listed an Imac, which is also what I have. |
Value lost, sometimes even plugin itself lost with 10.1.1 | kinghand | macOS | 6 | 04-03-2012 12:58 AM |
Please HELP! Grey Screen - Lost song, Lost Soul... | deeegenerate | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-12-2010 08:05 PM |
More Lost or Deleted Regions-Really lost this time.... | SunsetLodge | Pro Tools TDM Systems (Mac) | 6 | 11-10-2010 06:58 PM |
Lost thread "Stolen or lost iLok" | stargazer | Pro Tools TDM Systems (Mac) | 0 | 03-18-2006 04:44 PM |
DUY..... all is not lost.... | Jon_Atkinson | Pro Tools TDM Systems (Mac) | 0 | 11-10-2005 01:33 AM |
