Freeze on "Creating DAE objects"
This problem is killing me.
When I open Pro Tools it freezes at Creating DAE Objects. I've tried everything on General Troubleshooting. At first, when I would move all the plug-ins to the unused file and open up Pro Tools, then open it a second time with the plug-ins back to use it would start up. But now even that doesn't work, like it's getting worse. I haven't changed anything on my system for a long time, and PT was working brilliantly for a long time; then this started happening seemingly out of nowhere. I'm on a Vista 32-bit PC. When PT freezes, the computer does not. But for some reason it won't let me close or "end process" PT; it just stays there "not responding" while everything else about the computer is working fine. So I have to restart the computer because PT is just there completely unresponsive. HELLLPP MEEEHHH!! Any input is much appreciated. |
Re: Freeze on "Creating DAE objects"
Forgot to mention, I'm using the 003 Rack.
I've searched the DUC for this problem and some people have had similar issues, some on Mac systems and some with slightly different errors. But they haven't been resolved. |
~ tom thomas Formerly hobotom Pro Tools Ultimate 2023 HDX Hybrid HD Omni and 192 I/Os Windows 10 Intel Hexcore i7 All Samsung Pro SSDs Ampex MM1200 2" 24 trk tape Outboard: UREI, Eventide, Lexicon, Yamaha, TC Electronics, Orban, ART, EchoAudio, Dolby, Hughes, API, Neve, Audio Arts, BBE, Aphex, Berringer, MOTU, dbx, Allison, etc. Plug-ins: Too many to talk about. www.metrostudios.com |
Thanks Tom! I do have it installed. I never thought to uninstall it because Pro Tools had been working great alongside IE8 since I first installed it. But I'll do that right now and see what happens.
My Sandra report: SiSoftware Sandra Computer Model : Gigabyte EP45T-DS3R Workgroup : WORKGROUP Host Name : Gossamer User : Kayhan Processor Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Speed : 2.4GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing Computer Mainboard : Gigabyte EP45T-DS3R BIOS : Award (Phoenix) F2 06/18/2008 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.25GB DIMM DDR2 DDR3 Chipset Model : Giga-Byte P45/P43/G45/G43 DRAM Controller Front Side Bus Speed : 4x 267MHz (1GHz) Total Memory : 4GB DIMM DDR2 DDR3 Memory Bus Speed : 2x 534MHz (1GHz) Memory Module(s) Memory Module : Corsair CM3X2G1600C9DHX 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-20 4-27-8-4) Memory Module : Corsair CM3X2G1600C9DHX 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-20 4-27-8-4) Video System Video Adapter : NVIDIA GeForce 8800 GTS (96 SM4.0 1.1GHz, 320MB DDR3 2x836MHz, PCIe 1.00 x16) Video Adapter : NVIDIA GeForce 8800 GTS (96 SM4.0 1.1GHz, 320MB DDR3 2x836MHz, PCIe 1.00 x16) Graphics Processor Adapter : NVIDIA GeForce 8800 GTS (96SP 1.19GHz, 320MB 2x836MHz) Storage Devices WDC WD3000HLFS-01G6U0 (300GB, SATA300, 10000rpm, NCQ, 16MB Cache) : 279GB (C:) WDC WD1001FALS-00J7B1 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (E:) TSSTcorp CDDVDW SH-S223Q (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 8GB (D:) Logical Storage Devices Hard Disk (C:) : 279GB (NTFS) @ WDC WD3000HLFS-01G6U0 (300GB, SATA300, 10000rpm, NCQ, 16MB Cache) Porcelina (E:) : 932GB (NTFS) @ WDC WD1001FALS-00J7B1 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) HOME_ALONE_SE (D:) : 8GB (UDF) @ TSSTcorp CDDVDW SH-S223Q (SATA150, DVD+-RW, CD-RW, 2MB Cache) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8718F Audio Device : Giga-Byte HD Audio Controller Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte JMB368 IDE Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Network Services Network Adapter : Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.0) (Ethernet, 100Mbps) Network Adapter : Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.0) #2 Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows Vista Home 6.00.6002 (Service Pack 2) Platform Compliance : x86 Windows Experience Index Current System : 5.6 |
At a glance your system looks pretty good. I bet it's the IE8 thing.
Ok, weird. I uninstalled IE8 but it would still freeze at Creating DAE objects. So following that link you sent me I disabled Vista's DEP, restarted and launched PT successfully! But I wanted to check if it was a permanent and consistent fix so I restarted again and launched PT again. Now it froze on "Reading Preferences." And once again it won't even let me "end process" PT, I have to do a complete restart.
Any other ideas? Thanks again for your help. |
Im on XP and loaded win with sp3 and IE 8 and could not fix it until I did a fresh reformat without IE8 on the CD. Thats just me though.
Try right-clicking on Pro Tools and choosing 'Run As Administrator'...
Thatz what I was gonna say...Also have u trashed ur Databases folders on ALL ur drives?... & what interface do u have?? Just askin b/c if its an 00x, u could try powering down & changing firewire ports...thatz helped in some occasions...
I always run as administrator. And I've tried using a different firewire port too. No luck!
freeze on "creating dae objects" | jloakland | Pro Tools TDM Systems (Mac) | 1 | 06-27-2011 12:29 PM |
PT9, Win 7 64 bit & "Creating DAE Objects" freeze | The Bagwhan | Windows | 5 | 12-08-2010 01:35 AM |
Pro Tools LE (7 & 8) "creating DAE objects" freeze | glitchbent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 04-22-2010 02:22 PM |
M-Powered 7.4cs2 Freezes on "Creating DAE Objects" | Haon99 | Pro Tools M-Powered (Win) | 6 | 03-29-2009 09:26 PM |
System Hangs on "Creating DAE Objects" In Vista 32 w/ Digi003 | Rostafunk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-19-2009 02:18 PM |
