Old 09-24-2011, 10:31 AM
vermilion vermilion is offline
Default Elastic Audio
As a new pro tools user, i have received alerts saying that i have run out of CPU power, and elastic audio processing could not keep up. How do i disable elastic audio? This seems strange as i have only one track currently recording, working with Pro Tools LE 9.0.2 on Mac OS X 10.6.8.
Sorry if this is a stupid question.
Old 09-24-2011, 12:06 PM
brickroadstudio brickroadstudio is offline
Default Re: Elastic Audio
on the track select the elastic audio switch and disable it, hold option to make all tracks disabled.
Old 09-24-2011, 04:54 PM
danander11 danander11 is offline
It's probably how you have PT set up for your computer. Read through the tweaks and such to see about setting processors, playback buffer, etc... Doing that first will save you a ton of headaches.
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 09-25-2011, 04:33 PM
PD-John PD-John is offline
Just a tip with using elastic audio - if you're happy with your elastic audio edits, you can consolidate the regions and then disable elastic audio. You're committing to your edits but saving on real-time processing power.
2011 MacBook Pro 13" 2.7GHz i7 8GB RAM
Mac OS X 10.9.3 Mavericks
Pro Tools 11.1.3
Focusrite Saffire Pro 40 w/ Saffire MixControl v3.4
Focusrite Forte with Forte Control v1.1
Old 09-25-2011, 05:04 PM
Never commit before making a duplicate of your track first... hide it and make it inactive. If you later need to go back you can.
Here I am,
Hobo Shave!
Old 09-26-2011, 06:06 PM
Yup!
Pro Tools 11.1.3
Elastic Audio can't render-then loses audio file boneboy macOS 5 04-30-2014 04:57 AM
Elastic audio taking VERY long to analyze audio? DJ Hellfire Pro Tools 11 3 07-03-2013 05:44 PM
PT10 elastic audio unable to analyse audio files chinopepito macOS 8 03-30-2013 11:03 AM
Render elastic audio alert when not using elastic audio! weird! jjboogie macOS 7 03-26-2012 09:01 PM
Elastic AUDIO, or Elastic TIME? SoundWrangler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-13-2007 11:21 PM
