Old 08-17-2008, 06:59 PM
twig twig is offline
Default adjust bounds? insuf. audio data within fade bounds...
standard crossfade and " one or more fade requests are invalid due to insufficient audio data within the fade bounds. you may skip the invalid fade requests , or adjust the bounds for those fades (wher possible)" then give the option to " skip invalid fades" or "adjust bounds" any suggestions? thanks
mac book 2g 2g mbox2 pro, lacie quardra ext, PT 7.3.1 and a great dog
Old 08-18-2008, 02:16 AM
Phil Ogden Phil Ogden is offline
Default
Crossfades require the regions to 'overlap'. This messages results when they don't. Zoom in and try a fade-in and a fade out at the region boundaries.
http://www.myspace.com/philogg
Old 08-18-2008, 07:14 AM
Default
thank you . im still getting this when tracks overlap. i select a "larger crossfade" it gives me the message....i cleck adjust bounds, and it replacces my fade with a "smaller " cross fade.... im confused. i know its something obvious, sorry to waste your time phil. any other suggestions? cheers
Old 08-18-2008, 08:42 AM
Taliq Taliq is offline
Default
The fade on that region is longer than the audio file. I get this all the time when I use an audio suite and PT generates a new file which is the length of regions. You can't crossfade then.
Studio:
PPC G5 Dual 2.7GHz, 4GB DDR SDRAM, Mac OS 10.4.6
Pro Tools HD 7.1, 6 DSPs, 4x192 i/o
SSL 9000 J-Series
Private:
MacBook 1.83 GHz Intel Core Duo, 1GB DDR2 SDRAM, Mac OS 10.5.3
Pro Tools LE 7.4.2, MBox
don't ask - always adjust bounds bad jitter Pro Tools TDM Systems (Mac) 2 03-12-2008 03:58 PM
Crossfades-"Adjust Bounds" every time??? cloughri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-10-2007 11:39 AM
what deos adjusting fade bounds do? nowhere Tips & Tricks 2 04-11-2007 08:30 AM
Adjust Bounds - crossfades desdichadisimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-07-2006 09:28 PM
Fades - Adjust Bounds problem mrtunes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-19-2006 12:02 PM
