Old 03-21-2009, 06:17 AM
jeremyroberts jeremyroberts is offline
Default Re: ESATA or FW 800
Considering large drives can cost less than DLT tapes, I started using SATA drives as "tape" using this eSATA dock:
http://www.amazon.com/Thermaltake-Bl.../dp/B001A4HAFS
The drives just drop in... no enclosures to worry about. You can use 3.5" or 2.5" drives. It has a USB2 port in case you absolutely must take it somewhere without eSATA. Best $40 I ever spent.
--Jeremy
Old 03-21-2009, 09:44 AM
Howardk Howardk is offline
There was mention that eSata was not compatible with ProTools. . . really? If Sata is compatible, then eSata should be compatible. Regardless, I have never had a problem and have done 80% of my projects on Sata/eSata for the last year +.
This eSata adapter for the MacPro was mentioned earlier in the thread. It is a must have if you are using a Mac Pro and fits even if all 3 slots had HD cards because there is an additional backplate with no slot where this can be placed on my Quad Core Mac Pro.
http://eshop.macsales.com/item/Newer...ology/MPQXES2/
I use the Thermaltake mentioned above, on USB for backups, and it works great. However I am not comfortable with a session drive sitting open like that. . . could get knocked over with a guitar neck or other easy-to-happen acident. . .
eSATA & TDM ? Russ M. Pro Tools TDM Systems (Mac) 0 01-27-2014 10:01 AM
eSata Violin Vienna General Discussion 8 12-24-2009 12:49 PM
anyone using esata on MBP? therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-14-2009 08:34 AM
> eSata on a Mac Pro w/HD3 Howardk Pro Tools TDM Systems (Mac) 4 12-05-2007 04:24 PM
eSATA?? wildplum Pro Tools M-Powered (Win) 1 08-16-2007 01:09 AM
