Old 01-21-2008, 10:08 AM
mik mik is offline
Default pull up 24fps to 25fps with waves soundshifter
I'm trying to put an 24fps LtRt mix for a Pal TV telecinema which was done at 25 fps.
If my math is good, i have to pull up 4,16% the audio speed.
I'm trying to do that with the waves soundshifter in stéréo mode but the result doesn't feel very accurate.
Something strange is that if i put one of the factory preset "pull up 4,1%" the ratio is going to 1,0427... why isn't it at 1,041 ??
thanks for your help.
Old 01-22-2008, 01:23 AM
mik mik is offline
Default Re: pull up 24fps to 25fps with waves soundshifter
no one ??
Old 01-22-2008, 05:20 AM
C C is offline
Your maths is correct.
Did this using Pitch and Time as well as with the Tweak head setting of Import Session data on the last project we did.
C
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Old 01-23-2008, 06:00 AM
mik mik is offline
thanks for your help. The ratio was finally good.
I'm going to write to waves about the strange ratio "soundshifter" plug-in put with the 4,1% pull up preset.
HTML code is On
24fps to 25fps audio first ? barakka Post - Surround - Video 6 07-17-2013 02:14 AM
Using 25fps to 24fps then the converted 24fps to new 25fps. Stay with me on this! abes Post - Surround - Video 2 03-01-2013 09:36 AM
Auto Match Pull Factors & 25fps to 24fps workflow tj_davies Post - Surround - Video 4 03-05-2008 09:26 AM
25fps - 24fps - Help! paulspurrier Post - Surround - Video 1 10-03-2004 02:36 PM
25fps into 24fps? Xabi Post - Surround - Video 1 11-04-2002 03:10 PM
