closing a effect-windows from off the Dock
when selecting a track and pressing for example the EQ knob in the CHNL on the Dock's Screen, the effect-window pops-up on the screen. This is normal behavior but is there a Eucon command to close that window again ?
Philippe Meiresonne (Belgium) http://www.pm-mastering-studio.com SYSTEM 1 : Main recording - HDX MAC Pro 2023 M2 Ultra Running Sonoma 14.4 ProTools Ultimate 2024.3| 1xHDX Card | Mac Pro M2 Ultra 128Ram 2TB|3x PRE | 2x Avid 96 |1x Avid 192 I/O 16/16 Analogue | 1x Acid HD I/0 16/16 Analgue Midi I/O | D-Command ES +16 fader Pack | Xmon | Eleven Rack + Dolby Atmos 7.1.4 Surround Adam S3H speaker System System 2 : Project System - ProTools CARBON Running Sonoma 14.4 MacStudio M2 Ultra |64 GB RAM | ProTools 2024.3 Ultimate/Studio | SSL2+ | AVID S1+DOCK + ProTools|Carbon + ProTools|Carbon PRE |
Re: closing a effect-windows from off the Dock
In General Tab in Eucontrol settings you can select checkboxes to open plugins when editing and to close when exiting.
To do this manually from your Dock you would need to set up a Eucon Command to open and/or close plugins either using buttons on your Dock or the soft keys on your tablet. |
If you touch Input, Mix or Heat blocks on the function scroller (Avid Control) it should also close any active plug-in windows invoked such as from EQ or DYN, assuming you have “Close Windows on Workstation When Editing” ticked.
best, Jeff Sent from my iPhone using Tapatalk Pro |
Error when Dock is switched on before windows boots | domilik | Avid S1, S3, Dock and Control App | 10 | 11-05-2017 10:24 AM |
Touch screen and closing Plug in windows | CD Productions | Avid S4/S6 | 1 | 04-10-2017 01:24 PM |
Forced to restart PC after closing Pro Tools 11 (Windows 8.1) | Shordes | Pro Tools 11 | 3 | 12-03-2014 04:19 PM |
PT 11 Crashes While Playback When Closing Plugin Windows | SpaghettySaussage | macOS | 0 | 10-26-2014 09:46 PM |
Key command for closing plugin windows? | IO Composer | Pro Tools TDM Systems (Mac) | 9 | 08-10-2009 04:38 AM |
