L2 Rack with Digi002 routing help
I'm practically a noob at some of this stuff, so please bear with me.
I have a Waves L2 rack which is running through my Digi 002 via SPDIF. I'm trying to figure out how to get the signal routed correctly so when I bounce down a session I get the signal from the L2 instead of the Digi002. So far, I've tried setting the Bounce Source to 17-18 (SPDIF in I/O), no luck. Then I set up an aux channel, bussed all of my tracks to it and set a send to Interface 17-18 and printed it to a new audio track. This works, sort of. Taking the L2 in and out of bypass prints to the track, so I know it's picking up the signal, but the volume is very low. I'm using PT8 on Windows. Thanks for any help! |
Re: L2 Rack with Digi002 routing help
Not sure, but I think you need to setup a hardware insert point(using 17&18 for send AND return). Then insert across the Master track(Read the manual for using Hardware Inserts).
As an option(instead of using a hardware insert), don't use BTD. Set the output of all tracks to SPDIF(17&18), then create a new stereo AUDIO track, with output to Main L&R and input to SPDIF. Put this new track in record and roll(recording the L2-processed audio to a new stereo track). Then trim the new audio clip and "Export Clip as File"
Power Mac Digi002 rack and Digi002 with faders | jpkorell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-08-2011 11:17 AM |
Talkback Routing C24 with DIGI002 | Ghostwood Records | ICON & C|24 | 2 | 04-10-2011 10:54 AM |
Routing soundcard output through digi002 rack | digimike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-25-2007 12:03 PM |
MIDI Routing & Expansion with Digi002??? | BeatMechanic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-30-2005 11:53 PM |
Digi002 Rack shipping with Digi002 plugin pack? | Vaphoron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-22-2003 02:38 AM |
