Error 3512?
Hi all!
I'm getting this error when trying to add plugins after working with the session for a while. The audio still plays back fine but I cannot add more plugins--can't find what this error means anywhere! |
Re: Error 3512?
It also appears that this only happens with some plugins, not all.
Re: Error 3512?
What OS are you using?
Which version of PT (have you made sure your plugins are up to date with the version you are using)? You need to throw us a bone here and give some more detailed info if you want any help.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Re: Error 3512?
Curiously, it seems to be some sort of plugin "overload" error. When I deactivate tracks with a lot of plugins it will let me add new ones. Other than this error everything appears to be working perfectly. |
Re: Error 3512?
There is no such patch. You'll need PT 8.0.5 or above for Win 7.
Re: Error 3512?
Re: Error 3512?
Same issue here on PT10 with Win7, no more than 30 waves plugins within a session.
Re: Error 3512?
Same issue here. When i use H-Delay i cant use True verb or vice versa... neither the Q1. It says that my sistem is low on resources. The interesting fact is that i dont have this problem on my desktop pc with lower cpu power then my laptop..... WTF???
Re: Error 3512?
I didn't say you were lying.
First, the patch/fix in the vid is not from Avid/Digidesign. Second, obviously, the un-offical patch/fix in the vid is NOT working for you. Third, what I told you is the truth and good advice, 7.4 is not qualified to run on Win 7 and you will need 8.x or better to run PT on Win 7 with any assurance of support & success. Good luck- |
Re: Error 3512?
H/W Buffer Error (pro tools error -6104) Only 1 audio track running. | kieran.mia | macOS | 1 | 01-29-2013 01:39 AM |
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error | EricMulhern | macOS | 1 | 11-20-2011 05:39 PM |
Error 9073 and Error Increase/Reduce H/W Size during playback Digi001 | Karma180 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-05-2011 07:46 PM |
Error type 10,address error ,illegal error, buss error ,illegal instruction | KasticK | Pro Tools TDM Systems (Mac) | 3 | 05-14-2003 11:21 AM |
Buss error,Address error,ilegal instruction,error type 10 | KasticK | Pro Tools TDM Systems (Mac) | 1 | 02-08-2003 05:49 PM |
