M-Powered PT LLM w/ M-Audio HW ??
What's the situation recording and monitoring live, "THROUGH" Pro-Tools with the M-Audio setup ?
Is it a solution similar to the M-Box, controlled with mix knobs, and by muting the live rec enabled track ? or is there a software controlled LLM circuit built into the HW, similar to the 001 / 002 allowing you to switch the live rec enabled track monitoring, to the LLM circuit, for monitoring through the track ??? Anyone know ?
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
Re: M-Powered PT LLM w/ M-Audio HW ??
Dave download the demo and try it..I just installed, gave it a listen and then uninstalled..Maybe when I have more patience and time I will reinstall the demo and give it a more thorough investigation.I can forsee the crackers all over this, like stink on a monkey.
Bazzle |
I don't have any M-Audio H/W to try it out with, and the LLM situation with the M-Box is a HW feature that doesn't exist.
if the LLM scenario works like an 001 / 002 I'll likely replace all m-boxes from the studio and home with the M-Audio HW equivalent.
The 24/96 has a software mixer section with patchbay/router and I expect that is what you would use in place of the Mbox's hardware monitoring.I will check it out again later.
Bazzle |
I've used it and everyhting runs fine on my Delta 1010lt.
The latency is great...near zero and much better than my M box. I opened an aux channel assgined an input from my Delta,and plugged a bass in and there was no noticable latency or Delay what so ever and that was at 128 buffer.
2006 'Blackbook' Core Duo 2.0 ghz. 2 gig OWC RAM 10.5.8 PT Mpowered 8.04, Logic 9.1.1 Waves SSL,Omnisphere,Korg Legacy Digital Absynth 4, EZ Drummer Project Mix I/O w/ Black Lion Mod Axiom 61,25, Korg Nano Pad |
PT m-powered doesn't see sp/dif from m-audio 2496 | ktommy | Pro Tools M-Powered (Mac) | 8 | 11-30-2006 10:38 PM |
PT M-Powered with FW400 bus powered audio drive? | bruceup | Pro Tools M-Powered (Mac) | 5 | 07-06-2006 01:32 PM |
Who uses an M-Audio 410 and PT M-Powered? | holyspicoli | Pro Tools M-Powered (Mac) | 4 | 05-15-2006 09:21 PM |
m--audio transit with m-powered | clusterer | Pro Tools M-Powered (Mac) | 4 | 12-24-2005 11:25 PM |
M-Audio Powered and PT FREE | GaryMC1 | General Discussion | 0 | 04-07-2005 08:46 AM |
