Old 10-04-2022, 07:27 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Default Re: 2022.9 Win Can't select between markers?
Originally Posted by DFT View Post
But the other method is faster for me and has other advantages. Remember that period-#-period gets the cursor to the loop beginning marker[.........]you can rapidly grab different loop sections on the fly without having to scroll your screen at all.
Whoa.... thanks for sharing this!
Quite regularly I work with audio voiceovers read from a PDF with page numbers. Each "page audio" needs to be separated and I use markers to separate on grid. So there might be 70 markers.
period-#-period is wonderful!!! Now all I need is a handful of "negative markers" , because page 1 is usually marker 3 after 1 and 2 are front and inside covers. Hahaha!
Earlier this year I learned about period-#-asterisk for Window Config recall. Been spending time learning and reading this forum... My work keeps getting easier and faster!!
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 10-05-2022, 06:55 AM
The Weed's Avatar
The Weed The Weed is offline
When doing Described Video, I may have 400 to over 700 Markers based on Timecode. I just keep the Marker List open. The Markers are named for the Timecode and sorted by Time.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 10-05-2022, 08:03 AM
lego lego is offline
Something seems broken in how PT reads the Num Pad:
go to Keyboard Shortcuts
Activate "Search by Key"
Press Shift + some Num Pad keys
Result: keys 1, 2, 3, 4, 6, 7, 8, 9, 0 and "Comma" are not recognized as Num Pad keys but standard cursor keys instead.
If you use other modifiers (Ctrl, Alt, Start) _without_ Shift (or no modifier) all the Num Pad keys are recognized properly.
(Tested on Windows)
So Shift + NP "Comma" is not read properly and cannot trigger the expected action.
"The Mackey Big Knob is, you press little button and they can hear through the headphones, you can say whatever you wanted to them without you having to yell." by Tad Donley
Old 10-05-2022, 05:46 PM
The Weed's Avatar
Windows 10 and 2022.9. I too can't do .#. Shift .#. to get a selection between Markers. However, if I open the Marker List, click on one Marker in the List and then Shift+Click another Marker in the list, there will be a highlighted area on the Track my cursor is in between the two Markers.
SonoBus
Old 10-05-2022, 05:52 PM
I reported this Shift + Num Pad behavior as a bug, hope for a fix
  #16
Old 10-18-2022, 09:29 PM
DFT DFT is offline
It's a bug and in the pipeline.
Current Response:
Entered on: 10/18/2022 1:40 PM Entered by: King Jamal
Hello,
I received an update from our team regarding the issue we encountered with the shortcut keys.
This has been confirmed as a bug that has been logged on our end. Here's the bug number for reference: <PT-291640>. Feel free to subscribe to Pro Tools release updates on any of the two knowledgebase articles below:
Release Dates and Versions for Pro Tools (v9 and later, includes Pro Tools HD): https://avid.secure.force.com/pkb/articles/faq/en393795
Pro Tools Release Notes: https://avid.secure.force.com/pkb/ar...-Release-Notes
From this point on, we will need to leave it up to Engineering. Just a heads-up, we cannot promise an ETA for any type of fix. Since they won't be requiring anything more on our end, please let me know if you have further questions before closing this case.
Best Regards,
King
Avid Global Customer Care
PT10 Win7 x64 Dell 690P Dual Dualcore Xeon 3.0Ghz 16Gb Ram, UAD2 Quad (2), Steinberg MIDEX8 (2), RME HDSPe and A&H ZED R16 FW.
  #17
Old 12-29-2022, 12:36 PM
smurfyou smurfyou is offline
2022.12 Release Notes:
"Edit selections can once again be extended to a marker using SHIFT and numeric keypad shortcuts (PT-291640)"
I'm not updating yet but maybe it's fixed?
~Will
  #18
Old 12-29-2022, 02:41 PM
DFT DFT is offline
As the very happy OP I can assure you it's working.
Can't select MIDI Notes after Quantizing them in 2022.6 [PT-289219] Dizzi45Z Pro Tools 93 10-18-2022 08:17 AM
2021.6 Clips/Markers Grid Select Broken the.engineer Pro Tools 1 05-26-2022 02:26 PM
Beach ball in markers, select all, etc. improvpwnd Pro Tools 2020 22 08-31-2020 09:51 AM
Select area of audio in between markers mediapimp Pro Tools M-Powered (Mac) 2 10-20-2009 09:10 AM
Can't select audio between markers bwillman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-25-2008 08:38 PM
