Old 11-05-2021, 03:09 AM
Rammelt Rammelt is offline
Default Fader on S1 stopped working after update
Hi guys,
I hadn't turned off automatic updates on my iPad, so I had to run the EUcon update and it prompted me to run the S1 Firmware update.
After the FW update, fader 7 does not move. It sends data but the motor seems dead; whether I move the software fader on my iPad or in PT it doesn't move.
Has anyone else experienced this?
I'm on PT Ultimate 2021.10, OS 11.6.1.
BR,
John
John Rammelt
Producer / Composer / Post
Hajp AB
old site:
Soundfactory JPR
Old 11-07-2021, 10:55 AM
EddieJones's Avatar
Default Re: Fader on S1 stopped working after update
I think it might just be a coincidence but this is a sign of dirt in the fader. Try moving back and forth fast a lot, try blowing some compressed air into the slot.
Old 11-07-2021, 09:20 PM
thanks for your reply. I tried this already but it didn't change anything.
When the S1 is powered up, there is a slight resistance in the faders when nudging them, except the fader 7, which just glides frictionless.
BR,
John
John Rammelt
Hajp AB
old site:
Soundfactory JPR
Old 11-09-2022, 07:29 AM
Mattiasnyc Mattiasnyc is offline
Originally Posted by Rammelt View Post
BR,
John
Did you find a solution to this? Just happened to me on a brand new unit.
Old 11-09-2022, 08:15 AM
EddieJones's Avatar
Fader 7? If this is a brand new unit you can get it swapped out.
Old 11-09-2022, 10:29 AM
Fader 5 in my case, but it now seems to be intermittent.
Just seeing if there was a possible driver or firmware issue or something else that may have been a problem (that I'm now running into).
And 'yes', surely I'll reach out and get it swapped if it reoccurs. It first happened today so I'll see if it persists tomorrow/Friday.
Thanks
Old 11-09-2022, 11:13 AM
EddieJones's Avatar
The only issue we know of is a rare case where the firmware locks it out and the S1 needs a full power cycle to fix.
Old 11-09-2022, 11:37 AM
Thanks Eddie.
Old 12-30-2022, 12:15 PM
RayTurner RayTurner is offline
Hey guys,
Brand new unit out of the box as well, installed the firmware update, now fader 1 will not register moves in pro tools, but if I use the mouse in pro tools to adjust my fader I get perfect response. Anybody had any luck with this issue?
Thanks, hope all is well
Ray
Old 12-30-2022, 12:24 PM
Hi Eddie,
Has anyone found a fix for this? Just got my new unit today and havent even had it out of the box for an hour and having trouble.
Thanks for all your help,
Ray
PRO TOOLS 8LE was working on windows 8, stopped working after 8.1 update... Jon Vandenbor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-01-2015 02:10 PM
C24 fader question. They stopped working albee1952 ICON & C|24 22 12-01-2014 08:13 PM
Midi stopped working after Osx 10.8.3 update Fiachra macOS 4 03-26-2013 05:42 AM
PT LE 8.01 stopped working after MacOS 10..8 update on 09/02/2010 ericmedley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-07-2010 12:32 PM
