Audio Suite Chain
I like that you are able to have several audio-suite windows open at the same time. I will like to chain the different effects but I can't find my way around it. I have seen you have to press shift when you open a plug-in, but I can only use one at a time. Do I misunderstand this - or is it possible and how to it?
Thanks for any help! |
Re: Audio Suite Chain
Check this out: http://www.theonlineaudioschool.com/...e-plugins.html
I know this page, but I still don't get it. I open the plugs with shift button pressed and I can open several windows - but they don't seem to be chained in any way. They work as individual plug-ins.
The Reference guide or the What's new in PT 10 doc doesn't mention serial rendering at all, nor is it listed as an AudioSuite improvement. There's also no logical way that I see to order the plugins for rendering.
Thanks. In the article above it says that you can render in series. I guess the article is wrong then.
It is wrong, but please correct me if there is an unreported way to do this.
It's not so much wrong as badly worded and explained.
What the article appears to be trying to say is that now you can keep a 'chain' of audio suite windows open and then use them one after another (in series) on the same audio clip, thereby creating a clip that has been rendered through a chain of events. The difference between 10 and previous versions is that while this would have been possible before by using audiosuite plugin presets and opening and closing each plugin you can now leave them open (or in a window configuration set) and set to your preference. So not wrong in theory but definitely not a chain in the sense of VSTRack in Soundminer for example. C |
Audio Suite plugin chain questions | NBarnes21 | Pro Tools 10 | 2 | 12-20-2012 09:49 PM |
Audio Suite process puts new audio in audio bin | Fritz12534 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-21-2009 08:55 AM |
Audio Suite Prob: "No Audio Selected" | PTGuy | Pro Tools TDM Systems (Mac) | 4 | 05-02-2007 12:21 AM |
Audio suite effects on an audio track question | Majorek | Tips & Tricks | 7 | 02-08-2007 08:25 AM |
logic audio and audio suite plug in issue | alexmorris | Pro Tools TDM Systems (Mac) | 0 | 09-09-2002 03:33 AM |
