Old 09-29-2022, 02:23 AM
abx992000 abx992000 is offline
Default Close Window when no longer editing
Hello everyone,
I have the following problem:
I would like to operate an EQ with the S6, for example.
I take the track in attention (from the S6), touch an EQ button, the EQ opens in PT.
Everything as I set it.
Now I use the EQ and when I'm done with the settings and switch to another track using the Attention Knob.
Although I have set "Close Window when no longer editing" under Workstation-General, the EQ of the first channel remains open.
Only when I click on another channel in PT it will disappear, or if I use Strg+Alt +W
Can't I configure this when used only by the S6?
A second question:
Is it possible that if I have channel 1 in Attention and the EQ is opened, for example, that the EQ in Pro Tools automatically opens when I click on channel 2 - if it also exists in channel 2?
Best regards
Stefan
Old 09-30-2022, 08:47 AM
EddieJones's Avatar
Default Re: Close Window when no longer editing
What do you have this set to? "Open Windows on Workstation When Knobs Assigned"
"Open/Close window when editing/Exiting" option and Cubase 11 anason-records Avid S1, S3, Dock and Control App 7 10-28-2021 01:14 PM
How to close plug-in window after editing Mishabou Avid S4/S6 2 04-15-2020 09:52 PM
Shortcut for close plugin window José Luis Díaz Tips & Tricks 11 02-02-2018 08:06 AM
Window buttons don't close the window porkipine ProControl, Control|24, Command|8 0 05-02-2009 10:17 AM
Can't Close Preferences Window DavidMPierce Digidesign Hardware & Software 8 11-13-2000 08:23 PM
