Closed Thread
  #91
Old 11-07-2019, 12:54 PM
Default Re: Falcon 2
Actually, it does the same over here (macOS 10.14.6) even though the folder and .ufs file are there
  #92
Old 11-07-2019, 01:21 PM
ubxf ubxf is offline
yes i meant the library might be for 1.6 and not the updated 2.0 The file size is supposed to be 998Mb . I'm guessing that's why it works but we get some errors
  #93
Old 11-07-2019, 01:26 PM
Originally Posted by noiseboyuk View Post
I didn't get on with Falcon 1, but thought I'd try Falcon 2 as it was sat there in my Avid account. I installed just the 2.0 .exe in Windows. The Factory library was already installed on a separate SSD. I didn't uninstall Falcon 1 first, just installed 2 over the top. I don't have any new iLok assets I can see, but the support plan is current.
It loads, but I get an error on launch: "Unable to mount the Volume from C:ProgramData/UVI/Falcon/FalconResources.ufs". I've checked in C:ProgramData, and sure enough there's no UVI folder in there. Anyone any ideas?
Maybe you should have something installed in there?
Did you all let the installer put the files where it wanted to install them or did you do a custom install? When I installed F1 and the libraries when I purchased PT 2019.6 I let the installers put them where it wanted to. So I could also use my Digital Synsations stuff inside Falcon without having to manually locate things I just moved that ufs. file to where the Falcon installer put it's files. And when I purchased F2 from UVI I just let it's installer do it's thing and then activated F2 from within ILM. So I now have two Falcon license assets - one from Avid and one from UVI.
Now I don't know what's going on if one has downloaded/installed the Avid version of F2. Whether you get another license asset or what.
And again - F2 is at 2.02 from UVI. Looks like Avid only has 2.00
  #94
Old 11-07-2019, 01:30 PM
Just installed 2.0 over 1.6 with default locations
  #95
Old 11-07-2019, 01:54 PM
Geetar Geetar is offline
Originally Posted by digiot View Post
Is anyone getting strange "Authorization" messages with Falcon2?
I'm seeing similar errors - my old Digital Sensations library works fine, but the avid and falcon ones are throwing errors...
  #96
Old 11-07-2019, 03:15 PM
digiot digiot is offline
I get this error (attached image) as soon as I instantiate Falcon.
Like I stated before I downloaded Falcon2 from my Avid Account and installed it never having installed Falcon 1.6. I also used the Falcon Library that was available in my Avid account. The fact that it opens up anyway after dismissing the error is something I have never seen with an iLok Plug-in. It usually either opens or it doesn't if it can't find the proper iLok asset. I am not really going to loose sleep over this since I never used Falcon 1.6 on my old system. But it would be nice if Avid could chime in and let us know what's up
File Type: jpg Screen Shot 2019-11-07 at 5.59.53 PM.jpg (24.6 KB, 0 views)
  #97
Old 11-07-2019, 04:50 PM
I get the first warning, but not the 2nd. I don't think in my case its related to the Falcon Factory library - it sees that on my G drive, its there in Preferences and appears as a Tab on the right hand side. It seems to be missing some other core component that didn't get installed in that location in the error message above. If I try to load a patch, it frrequently tells me the wavetables are missing. I'm guessing that's in the missing resources.ufs.
Well, fun though this is, my patience is very limited considering I didn't get on with it the first time. It does serve as a nice dissuader should I ever get tempted in sales time to buy the full version. I compose in Cubase not PT, so I view this as essentially a trial.
Guy Rowland
www.guyrowland.co.uk
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
  #98
Old 11-07-2019, 06:28 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Mine is spitting some errors too after a straight install over the old one
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
  #99
Old 11-08-2019, 12:43 AM
Looks like many of us have the same issue, a missing Resources file. Truthfully I'm not sure I care enough to open a support case which tends to become like a second job, but would be nice if someone did and references this thread.
As it is, looks like the 2.0.0 install for aax is broken.
Guy Rowland
  #100
Old 11-08-2019, 03:22 AM
unkJE's Avatar
unkJE unkJE is offline
Looks like many of us have the same issue, a missing Resources file....
My guess is perhaps we don’t need the missing FalconResources.ufs, because:
Falcon 1.6.4 included Falcon Factory.ufs
Falcon 1.6.6 replaced Falcon Factory.ufs with FalconResources.ufs
Falcon 2.0.0 in my Avid account has both Plugsound Avid Edition and Falcon Factory – so
I removed FalconResources.ufs from my UVISoundBanks
(Happy to proven wrong – ‘cos it’ll mean even more to play with!)
Closed Thread
HTML code is On
How do I get Falcon to work? orvillej Virtual Instruments 14 01-06-2021 03:54 AM
UVI Falcon - stand alone? strangeLoop Virtual Instruments 1 03-07-2019 01:03 AM
Falcon Problem notr2d2 Virtual Instruments 5 01-05-2019 06:19 AM
Falcon UVI vs NI Komplete Ray Lyon Virtual Instruments 4 12-16-2018 03:08 AM
Falcon - New VI from UVI DonaldM Virtual Instruments 3 11-09-2015 06:45 AM
