Old 12-13-2010, 10:27 AM
drummer9 drummer9 is offline
Default 003 Stays Offline
003 stays offline. I reinstalled the driver (second time I have had to do this since installing 9). Still off line. I/O shows Aggregate as I/O for 1 and 2. Any suggestions?
Thanks
Old 12-13-2010, 10:50 AM
HD2 HD2 is offline
Default Re: 003 Stays Offline
Go to set up>playback engine and select 003. PT will close the session and re-open with 003 now connected. Of course make sure 003 is powered on.
Old 12-14-2010, 10:21 AM
gwrr gwrr is offline
I am having the same issue with my 002R. I just recently purchased PT9 and a Mac Mini. Moved away from my PC rig.
I selected Playback>Digi002 -though i feel my issue has been compounded, after the restart the 002 isn't available in Setup>Hardware. All the routing reflects the aggregate i/o.
I am going to try this:
"Mac OS X Only
If the solution above fails, you can try deleting the "com.apple.audio.AggregateDevices.plist" preference on Mac OS X. You can find this preference file in the following location:
* Macintosh HD > Library > Preferences"
seen here:
http://avid.custkb.com/avid/app/self...p?DocId=381131
and hope for the best - otherwise i'm deleting the driver and re-installing with the hardware hooked up. In the PT9 instructions i swear it said hardware didn't need to be hooked up for driver installation - gonna take a second look.
003 stays "offline" in PT OneMadSon macOS 7 07-26-2011 02:58 PM
BPM stays the same sricabla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-09-2010 01:23 PM
MBOX Stays Powered? Final Lap Guy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-23-2004 03:47 PM
green power led stays on cuba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-15-2002 12:28 AM
red 'peak ' LED light stays on. zedhed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-26-2001 09:32 PM
