#41
Re: New Massey "DTM" plug-in
Makes sense.
#42
But I CAN say that with my first and only experiment using this new plug (thanks Steve!) things seemed quite tight. Zooming in on the MIDI notes showed some slight discrepancy in timing related to the original "trigger" audio, but the sound of the sample (when combined equally with the original) was consistent enough for my ears/use! More testing is required before I could comment fully. But I like using this approach, even though it's WAY more "hands on" than using ReHab or Gog (which are "all in one" solutions). But the approach appeals to my "complete control" mentality - Others may do better to stick to the standard solutions if a simple/quick approach is needed.
Giles Reaves Somewhere Between Tennessee & Utah... |
#43
Nope. Some notes just don't get picked up, whatever the sensitivity. It's common in all of these kinds of plugins. So an 'add trigger' function would be extremely helpful.
#44
Can someone please help me figure out how to register this plug-in? I purchased the L2007 limiter a while back and so am eligible for the DTM. When I log in to the user area on the Massey site, I see that it is available for me to download. But after I install it, it asks for a registration key. I don't see any option in the user area to request a key, as so many others seem to have done without issue. Any suggestions?
#45
#46
I just did that, and he responded quickly with the code. Cool!
#47
This is an awesome plug!! Massey does it again. The analyzing does take a few minutes, on a G5 2X2.0 with 4 gig of RAM. This was a 3.42 minute snare track. Everything sounds to line up. I zoomed in and some are off by a few sample2, but as another poster mentioned, I couldnt hear it.
Its easy to draw in any midi notes and adjust timing velocity before committing to a sound or as an audio file |
#48
ARe you guys using this with PT8?
I'm getting this weird bug, where after I analyse the track and generate the midi, when I drag or spot the midi track into place it still pastes in WAY out of sync- like 35 bars later than the trigger sound. It's as though it adds 35 bars or so of silence. Once I line it up by eye, it's fine. But it's an extra pointless step. Also, I'm finding it happens a lot that the sensitivity misses some hits even when cranked up all the way, and there's no way to add triggers except manually in the midi editor later
William Wittman Producer/Engineer (Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!) |
#49
It's counter intuitive, but you need to drag all the way to the begining of the timeline. DTM generates from there whether or not your just working on a section later in the tune. Took me a minute of head scratching too. |
#50
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
"Factory Promo UB" - "Eventide" - iLok license - What plug-in is this? | Intini | Pro Tools TDM Systems (Mac) | 7 | 08-31-2012 08:27 PM |
Import session data... please break out "plug in settings" and "plug in automation" | yeloocevad | Pro Tools TDM Systems (Mac) | 19 | 10-05-2011 01:04 PM |
Does PT8 do a "Sample to Midi" type thing like Massey DTM? | cajonezzz | Pro Tools TDM Systems (Mac) | 2 | 01-22-2009 09:55 AM |
"Buss" and "Plug in" words grayed out... | amba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-10-2008 04:23 PM |
