Digi002 Rack & MOTU 828mkII via ADAT
Has anyone tried connecting a MOTU 828mkII to a DIGI 002 Rack via the ADAT or Opticle connections. I need some extra inputs for a project im working on and was wondering if this will work??
Cheers, ben. |
Re: Digi002 Rack & MOTU 828mkII via ADAT
It should work,using the ADAT optical protocol.
good luck
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Any help would be greatly appreciated.
Is there any special settings needed to get this working?? I Have hooked up the MOTU 828 to the 002 Rack going opticle Out of the MOTU 828 to Opticle In on the 002, but not getting any signal into protools. I can see the signal going into the 828 on line 1, and i have ADAT 1 selected in the protools channel input and the track record button enabled. Still no signal. Could this be something with ProTools LE 6.7 on Win XP? I Have also set Hardware Sync to ADAT. Could it be some setting in PT or something inside the MOTU. (opticle output is set to Adat) Cheers, Ben |
Motu 828mkII with PT 10 | Snickerz | Pro Tools 10 | 2 | 06-16-2012 05:11 PM |
Anyone using a Digi002 with a MOTU Traveler - ADAT? | zbocelle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-07-2009 05:09 AM |
motu 828mkII adat out to DIGI 002 adat in | Traveler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-24-2007 12:31 PM |
MOTU 828mkII and DIGI 002Rack via ADAT | boc12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-22-2006 01:17 AM |
Digi002 Rack & MOTU 828mkII via ADAT | boc12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-28-2005 05:30 PM |
