Old 11-01-2019, 03:40 PM
antonis's Avatar
antonis antonis is offline
Default Make all active tracks inactive when launching session
Hey all,
Would there be a key combo, that by being pressed whist opening a session, would force all tracks to become inactive?
I need to go into hundreds of big sessions (too long a story to explain why) and it’d be fantastic if I could minimise loading time.
Old 11-01-2019, 05:38 PM
Default Re: Make all active tracks inactive when launching session
I am not aware of a way to do that, but holding SHIFT while opening any session will make all plugins inactive, which might cut time considerably. Another option: drag all your plugins out of the Plugins folder and into any temp folder. As each session opens, you will get the usual message about missing plugins used in the session, but just click NO to skip the detailed report.
One last idea if you don't need to hear anything....rename the audio files folder by putting xxx in front(IOW xxxAudio Files) and be sure to skip the relink option window. After you're done, just delete the xxx and things should go right back to normal function
HTML code is On
suddenly can't make tracks inactive..it thinks they are inactive but they are active? awritersparadise Pro Tools 2019 0 08-27-2019 12:23 PM
Make inactive / active shortcut Mishabou Pro Tools 2018 12 01-02-2019 05:58 PM
Make plugin active/inactive amolin Avid S4/S6 2 06-06-2016 09:40 AM
No Start Key, How to Make Plugins Active/Inactive acstctws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-16-2012 12:55 PM
Toggle Active/Inactive Tracks mBoxLuvr Tips & Tricks 3 02-27-2005 09:39 PM
