cant bounce to mp3
When I try to bounce a file as an mp3 I get the following error. "The mp3 option cannot be enabled because: module intialization failed for mp3.dll. The mp3 demo period may have expired"
Re: cant bounce to mp3
What version did you upgrade from ?
Did you do a clean uninstall before doing the Pro Tools install ? If not can you do a clean installation of Pro Tools 10 ? |
I upgraded from 9. I uninstalled 9 then installed 10. How I do a clean install??
okay so I just unistalled everything and deleted all the files from my hard drive. I did a clean install of everything and I go to bounce the file as a mp3 and I get the same error message.
I have looked here and this folder does not exist on my hard drive:
◦C:\Program Files\Common Files\Digidesign\DAE\Codecs\MP3 What should I do now?? |
Well your not alone. I have exactly the same problem. Exactly the same upgrade path. Been trying to sort it out for days now. I had posted similar in another thread but the responses indicated they had no issues.
I was of the understanding this was bundled with both 9 and 10 so why is it talking about a demo period?
PT Ultimate with Native pcie card + Omni - 2014 MacbookPro - OSX Catalina - 16GB Ram - Sonnet TB Chassis -UAD2 Quad |
I know why it worked on your system!!
The order you installed the MBOX drivers. As the MBOX drivers are old and include Interlok drivers (Pace/Ilok) this was creating issues by overwriting your NEW drivers. As you now installed the MBOX drivers first the OLD drivers were overwritten when you installed the new Ilok drivers. I just went through hours of troubleshooting to work this out. BTW your thread gave me some ideas to come to this conclusion so cheers .
Bounce to Disk issues and bounce to direct show error. | SeattleHank | Windows | 7 | 01-01-2014 12:41 PM |
Elastic Properties Stuck? --pre bounce vs. post bounce | alithomas66 | Pro Tools 9 | 2 | 02-07-2012 05:56 PM |
Bounce to disk error - pro tools won't let me bounce the file! | HipHopHead | Pro Tools M-Powered (Win) | 1 | 05-14-2009 11:13 AM |
Bounce To Disk inserts silence at start of bounce - PT 6.4.1 | innerbooty | Pro Tools TDM Systems (Mac) | 1 | 04-18-2007 08:13 AM |
5.1 wont bounce. Says "bounce handler cant keep up try convert after bounce...." | Trash Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 05-21-2001 08:28 PM |
