4 vocals, 4 tracks into DIGI001 - what preamps?
I plan to record four vocals a'cappella soon.
I plan to use 4 vocal mics at once into 4 separate tracks (24-bit, 44.1) and would like to take them into PT via a DIGI001. Here's my plan: run 2 of the mics into the mic pres of the DIGI001 (input 1 & 2). Run the other 2 mics into a DBX 386 and run the SPDIF out from the DBX into the SPDIF in of the DIGI001. Do you think this will work o.k. and is it a good way to go? Also, if I can get one, would the Apogee Rosetta 2-chan. give me *noticibly* better sound than the DBX? |
Re: 4 vocals, 4 tracks into DIGI001 - what preamps?
Thanks for the advice.
I'd recommend either a stereo pair or one omni for an acappella group. Their sound is not the sum of the parts, but the group as a whole, similiar to that of a horn and reeds section or a drum set. A good acappella group can and will blend themselves properly, and the fullness you will capture by recording them as a section rwill not be replicated by close micing them indivually.
I'd recommend a pair of AKG C414B ULS or Rode NTK's for stereo micing, and the 414 or an AKG C4000B for a single omni. If you have the mic pre's you can do both close micing and section micing, and have the options at mixdown. Hope this is helpful. |
Are there plugins or preamps (upfront vocals) | dwayne00 | Tips & Tricks | 5 | 11-20-2006 02:13 PM |
Digi001 preamps good enough for vocals? | GothicV | General Discussion | 22 | 08-05-2003 05:10 PM |
Best Preamps for Vocals! | TiPo | Tips & Tricks | 5 | 03-16-2003 11:59 PM |
good preamps for rock vocals.... | Reverend Dan | Tips & Tricks | 19 | 10-15-2002 03:51 PM |
Are Digi001 preamps good enough for vocs/mics?? | tommydee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 58 | 07-23-2001 11:42 AM |
