Playback engine refuses to give the option I need
Hello,
These are my specs: 2.4 GHz Intel Core i5 4 GB 1333 MHz DDR3 Mac OS X Lion I've uninstalled and installed to trouble shoot many times, I've researched the forums and tussled with this for some time now - Built-in Input, Built-in Output, and Pro Tools Aggregate I/O are the only things I'm seeing in the Playback Engine; I'm getting no sound from my hardware interface (MBox). It continues defaulting to the built-in speakers. I've gone to apple > System Preferences > 'Avid CoreAudio Device' is available as an input and output, I gave that a go, upon checking the Playback Engine, Avid CoreAudio Device isn't available and it defaults to internal speakers the moment I play something back. Does anybody have experiencing pertaining to how this may be resolved? Thank you in advance. |
Re: Playback engine refuses to give the option I need
Hi, Have you installed the latest drivers for the Mbox http://avid.force.com/pkb/articles/e...nload/en379411 Launch pro tools holding the N key to open without any assigned audio engine, and in the playback engine settings page. select the Mbox as the audio engine/interface. That should be it Chris
PT11 Limited Playback Engine Option | Hadassah | Pro Tools 11 | 1 | 12-18-2013 10:40 AM |
No m-audio interface in current engine (playback engine) | SlicerSounds | Windows | 1 | 10-04-2012 12:27 AM |
Playback Engine -- Where's my Disk Playback option? | Wheeltard | macOS | 5 | 03-16-2012 06:19 AM |
Windows 7 64-bit PT 9.05 does not show Mbox 2 Mini as playback engine option | brunorio | Windows | 4 | 09-14-2011 06:46 AM |
8.0.3 and the plugin streaming option in playback engine... | mykhal c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-04-2010 06:06 PM |
