Exporting a WAV file with no meta data tag.
Does anyone know an easy way to export a wav file from protools that does not include the metadata information? I am doing a lot of mobile work and protools adds certain metadata to its files like track, date stamp, etc.. This information is causing problems with other software. Is there a way to get a clean wav file from protools? If not is there a third party batch converter that anyone has used successfully that does this well as I am dealing with a lot of files. Thanks for the help.
Re: Exporting a WAV file with no meta data tag.
No.. but the problem lies with your other software -- the spec specifically says to ignore unrecognized RIFF Chunks.
Rail
Hey Rail,
I agree with you, unfortuanatly these are files that are going internationally to mobile carriers and they specify no meta tag info in the delivery so its not something I can change on the back end. I think it's idiodic but I cant tell a major label that there system is outdated and they need to fix it. I have told them this before several times and its more trouble then its worth. Im just trying to figure out a work around. We have actually met several times over at S.C. studio. Thanks for the response. James |
Hi james,
I don't know of any utilities to do this -- it would be simple to write a quick app for you on Windows.. but you should try using SoundHack or BabaBatch -- first convert the Pro Tools WAV files to something else to strip the chunks, then convert them back to WAV files. Rail
Export from Pro Tools without Meta Data? | antiwebbite | Pro Tools 10 | 0 | 04-11-2013 03:23 PM |
Export wav without meta data | e_man | Pro Tools 9 | 3 | 03-02-2012 11:00 AM |
Importing Meta Data | RYLO | Post - Surround - Video | 5 | 01-16-2010 12:20 AM |
how to embed meta data | agus | Pro Tools TDM Systems (Mac) | 3 | 01-27-2009 10:13 AM |
PT7.4 strips meta-data on consolidate | Frank Kruse | Pro Tools TDM Systems (Mac) | 17 | 11-26-2007 11:17 AM |
