PMCD creation with Jam 5.0 / Superdrive
Has anyone created an acceptable PMCD using Jam 5.0 and an Apple Superdrive?
I have a client that is releasing a low budget Japan only "Best Of..." CD and he would like me to try this rather than spending larger $$$ at the Mastering Lab or Sterling Sound. Is this a workable idea or will the pressing plant just throw it (the PMCD) back at me? I know the common (best) way is using a Sonic Solutions or Sadie platform & high quality Plextor burners but I would like to try and save this guy some $$ if I can. Also, does anyone know if you can check for low error rates & zero CU errors with Jam, and will the program print a timecoded cue sheet? It already sounds like it's a bit much for the Jam/Superdrive combo but just thought I would see if anyone has had any success. Thanks.. |
Re: PMCD creation with Jam 5.0 / Superdrive
The only program that will produce a PMCD is Sonic Studio. Everything else is just a Red-Book CD. However, the plants will take a Red-Book CD produced from Jam. Jam will print out a time code cue sheet, but it won't check for errors. You need a separate hardware error checker for this. If you send the CD with the cue sheet, the plant will check the CD for errors before making the glass master. If it doesn't pass, you'll have to send them another one. Most CD plants are taking CD-R's and transfering them to a DDP format before cutting the glass master. Most of the time this isn't a problem. If you want them to cut the glass master directly from the CD you send them you'll have to make a special request. Some plants will do it, some won't, and some will say they will but end up transfering to DDP anyway. Good luck!
Which budget creation will run LE8? | Soliloquay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-20-2009 11:44 AM |
Creation Station Pro | LaForestPoetry18 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 11-24-2005 12:13 AM |
Unique ID Creation | Ungawa | Pro Tools TDM Systems (Mac) | 1 | 03-14-2005 09:49 PM |
PMCD creation with Jam 5.0 / Superdrive | BillSmith | General Discussion | 1 | 02-21-2004 10:51 AM |
Premaster (or PMCD) | MR808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-11-2003 07:40 AM |
