Creative Content Collection "*.big" files MIDI Xpand!2
So, I've run into the familiar situation of the "Factory Content" files not found when attempting to use most of my virtual instrument plug-ins (Xpand!2, Boom, Mini Grand, Strike!, etc). My factory content files are in the default install location: /Applications/Digidesign/Pro\ Tools\ Creative\ Collection Depending upon the Plug-in, I was able to set the location again, in the instances where the plugin presented a "browse" button on the error dialog box. Sadly, this information does not appear to be retained when saving the project. Additionally, the "Xpand!2" plug-in, in most cases, did not present the error dialog at all - it did present in one instance and I was able to set the file and use the plugin for a few minutes - it was lost again after a save (note, that I did not exit Pro Tools, I just saved). The "Strike!" plug-in presents a message to run the "SetStrikeContentLoacation" app - this is under the "/Applications/Digidesign/Pro\ Tools\ AIR/Content\" directory - unfortunately, this is an older "Universal" app and will not launch in 64bit OS X Lion. I have performed the ubiquitous "delete your profiles/database files, etc." routine and nothing helps. The above occurred after performing a full install of "Pro Tools 9.0.5". Side note: The "Strike!" plugin worked, after the initial install, when I opened a project previously recorded using PT 8.x - I think I saved after playing the project, so the bug might have something to do with the project Save save routine in 9.0.5? Any solutions would be greatly appreciated. Thanks |
Re: Creative Content Collection "*.big" files MIDI Xpand!2
Hi Adekyn, this could be a bug, given the Pro Tools 9.0.5 under OS X 10.7.x is a public beta release. Can you reproduce this behaviour with a newly created Pro Tools 9.0.5 session? What QuickTime version are you running? Does Pro Tools crash? Generally, Pro Tools saves it's preferences on closing the session and Pro Tools on a successful Exit.
Aaron Mulqueen - 001 HD Native |
Hi, I can recreate this in a new session. OS X 10.7.1 - w/ QuickTime version 10.1 (501) Pro Tools hasn't crashed during the session, on Save, or on Exit/Quit. Thanks |
If I'm not mistaken QT latest revision should be 7.7 for OS X and 10.1 is the revision for iTunes.
Have you try running under a new user account?
So, I ran the uninstaller ("Safe Uninstall" option) and reinstalled. The plug-ins work correctly. I haven't tested them all, but Xpand! worked out of the box.
One thing I have noticed that is fairly consistent (~80% of the time) when working with MIDI tracks is an odd "hang on Play" immediately after manually "resizing" a note in the MIDI Editor. If I tweak a note's length then reset to the beginning bar and press "Play", I hear a single note - then silence - the project halts playback. If I save the session and restart Pro Tools, then all is fine again. I can move the notes around without this occurring - it's seems to be relegated to the "resize" (lengthen/shorten) feature only. Not a show stopper, but annoying - kills productivity. |
Great! Ummm... I'd write up a bug report for that MIDI Note issue. You can submit them at IdeaScale. Make note of your system, OS X 10.7.x with Pro Tools 9.0.5.
Scary Story: Audio & MIDI content disappears on "Save" | scripguy | macOS | 2 | 06-27-2012 09:54 AM |
Creative Collection content files - can someone post them? | Guy Staley | Pro Tools TDM Systems (Mac) | 4 | 03-26-2011 01:09 AM |
Creative Collection Content gone awol | lennieh | Pro Tools TDM Systems (Win) | 1 | 12-02-2010 03:23 PM |
Creative collection content lost!! | LUISMI | Virtual Instruments | 3 | 01-27-2009 01:00 PM |
Pro Tools Creative Collection Content Location | Greg M | Virtual Instruments | 2 | 12-28-2008 06:09 PM |
