Playback volume hotter than recording volume..help!
Hi everybody, I could use some help. I'm running PT 12.5 on a mac.
I have all channels sent to a mixbus to my Master channel The MixBus is sent to a Print track. I listen to the volume using the Print track. But.. During recording, while not hearing any distortion from the peaks, when I listen to the playback I will hear distortion from the peaking. In other words, the levels I hear while recording are different than the result upon playback. i.e. The playback level is hotter sounding than that of the recording level. I've tried linking the 'record' and 'play' faders, but I still have this issue. Does anyone know how I can hear the same signal while recording than that which I hear upon playback? Any advice is appreciated.
PT 12HD Native / 192 / Yosemite / Cheese Slicer 3.33GHz 12-core / SSD Hard Drive / 32GB RAM Slate Raven MTi2 / Artist Control |
Re: Playback volume hotter than recording volume..help!
Yes when you stack audio tracks it will have a higher output than the original recorded audio track
If this isn’t what your asking, I apologize ahead of time
Yes Daniel, that sounds like what is happening.
Is there anyway to hear the output in it's true level in real time then?
Solo each track one at a time.
Adding tracks adds to the signal level. so you need to gain stage each track as recorded and gain stage the mix as well.
So what I would do, is put a few more things inline before I output my track.
I have my sessions all split up, rhythm / keys / guitar / lead / vocals Those all go into a two different stereo busses with different comps and settings and then those two stereo tracks output to my mains with another send to my print track. Sounds complicated but it’s not, I can adjust the mix rather quickly if the customer (or myself) don’t like it So then to find the problem areas in your track I would then put in a peak meter on each of the sub mixes to find out which section is peeking my levels (post compression and EQ obviously) I once had a problem with a session once in bar 42 (or something like that) turns out my VI drum program was creating some heavy velocity hits that spiked my mix levels Anyway you can find this stuff going through your song with a peak level meter
Daniel HDX - PT12.5.1 - HD I/O 16x8x8 Win10-Pro (v1709)- 6 Core i7-6850k - ASUS X99 Deluxe ii D-Command Main Unit - 'Ole Blue http://www.sknoteaudio.com/ plugins rock and are affordable. Last edited by YYR123; 02-08-2020 at 02:02 PM. |
"New volume" is not an audio playback volume | adzam016 | Pro Tools | Intro Discussion | 2 | 05-21-2016 12:26 PM |
Monitoring volume in Pro Tools doesn't match computer volume | Drakken | Pro Tools M-Powered (Win) | 0 | 01-17-2012 02:56 PM |
Recording volume is quite compared to playback.. | broken81 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-18-2009 01:27 PM |
Playback volume much louder than recording volume | BinkBonk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-26-2008 04:21 PM |
Recording level softer than playback volume | BinkBonk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 19 | 04-17-2006 05:21 PM |
