HD3 with HD Accel + Process card? (Hackintosh)
Anyone running an PTHD rig with a combination of Accel and Process cards? Ive been smooth sailing with my HD2 Hackintosh rig for a few years now. I just added an Accel card, and I cannot get them to work together.
Core + Accel works fine. Core + Process works fine. Core + Accel + Process = crashes! Ive switched the order but same problem. Does anyone have experience with this PTHD card combination on a Hackintosh?
PT HD4 10.3.8 / Mac OS 10.8.2 / Intel Core i7 3.4Ghz / Heat / X-Form / McDSP / Eventide / Soundtoys / UAD-2 / Ableton Live 9 Suite / NI Komplete 12 |
Re: HD3 with HD Accel + Process card? (Hackintosh)
No, but I can confirm that the order of HD cards need to be Core-->Accel-->Process
Im thinking that the HD Process card is not compatible with the HD Accel card. Is that a known issue? Anyone using both cards?
Of course I tried the correct order, then switched them just in case it was a hackintosh thing. Made no difference.
maybe your power supply isn't rated high enough?
mixing PCI/PCIX and PCIe cards? or all they all PCI/PCIX slots
I had mixed cards in G4s so it should work but I think I remember something about card revisions and early cards not working in a mixed rig.
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Thanks for the input...
Power supply is good to go, it should support HD4. All PCIX cards. Im thinking it might be revision/early card related, based off the fact that both work independently. Im running an unsupported rig, so obviously there are other possibilities. I swapped flex cables too,confirmed its not that.
checking card revisions should be your next step
I don't know if Avid will still upgrade them, they use to but given the age of the cards I wouldn't hold my breath
Aw, no way would I expect that. I think Im at least 5 years too late and running an unsupported computer. But I too remember an incompatibility between old and newer revisions. Thats the only thing that makes sense with all the troubleshooting Ive done.
Are you sure all your PCI slots are using the same chip? What's the mobo?
Most likely only three of your PCI slots are "native" and the others are bridged or emulated PCI. |
Pretty sure all slots are native PCI. Its the Jetway MB
FS: Protools HD3 accel, Hackintosh parts, Lynx LT-HD card | LDS | Buy & Sell | 0 | 10-06-2014 07:51 PM |
WTB HD Accel Process card PCI | capturemic | Buy & Sell | 0 | 06-13-2013 10:34 AM |
Process Card Question... Accel vs non Accel | gsilbers | Pro Tools TDM Systems (Mac) | 13 | 05-22-2013 01:51 PM |
Difference between accel card and process card? | MX582 | Pro Tools TDM Systems (Mac) | 10 | 08-11-2010 08:29 AM |
Process and Accel card | Zeljko | General Discussion | 1 | 09-15-2003 09:19 AM |
