Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 11-26-2020, 08:22 PM
blinduncledallas's Avatar
blinduncledallas blinduncledallas is offline
Default 2x Apollo 16's with SSL Sigma using PT Ultimate
Hi. This is my first post on here!
I have 2 x Apollo 16's that I use with an SSL Sigma and Nucleus 2 control surface.
Does anyone else have a similar setup so I can check what I am doing wrong? I know this is a mixture of UAD and SSL gear and many don't have this setup but it's worth a try.
I usually use my studio with Logic Pro X and had it working ok for me for a long time. Last week I have taken the plunge to set up and learn Pro Tools Ultimate.
I am having a lot of trouble configuring both the Apollo's and Sigma with Pro Tools because the setup is so different. I have set up the UAD Console I/O Matrix as per the instructions from UAD so it limits the I/O to 32 channels. I can send to all 16 stereo inputs of the Sigma but then I am left with no channels at all to set up as inserts in Pro Tools.
I actually bought Pro Tools Ultimate because I wrongly assumed the 32 channel limit was lifted and I could set up a preset similar to the way I used it in Logic. I guess I should have done more research!
My major confusion is with monitoring. I monitor from the main monitor output of the Sigma which goes into one of the UAD inputs so I can record and print the master from the Sigma. The UAD Pro Tools set up instructions say to leave 1-2 Output as the main monitoring output. If I do this, I will then lose one of the Sigma stereo channels which then leaves me with 15 stereo channels. This was never a problem with Logic as there wasn't a channel limit. If anyone has a similar setup or much more experience with Pro Tools, I'd appreciate some advice.
My second problem is with the UAD Console. For a while now, I have had to check the I/O Matrix preset menu on every system reboot because it doesn't seem to stick with the previous preset I had loaded. I then have to manually reload my preset to ensure it is working. What I have also noticed is that the console channels don't change at all when loading a preset. I am thinking it is time for a full reset of the UAD software but I am unsure of how to remove configuration files or simply do a factory reset. There are also no 'default' presets in the console load section or the I/O Matrix for some reason.
Protools 10hd and Ssl Sigma undadogz Avid Pro Mixing General Discussion 7 08-04-2018 11:31 PM
C|24 and SSL Sigma cman ICON & C|24 3 05-26-2018 05:55 AM
S3 and Sigma - Any users? Dizzi45Z Avid S1, S3, Dock and Control App 14 11-02-2017 04:42 PM
MCU Mode & SSL SIGMA v2.00 Raphie Artist Series 0 04-08-2016 12:20 AM
SSL Sigma ... Opinions Becharax General Discussion 16 04-02-2014 02:33 PM
