  #411
Old 11-29-2007, 07:12 AM
sunburst79 sunburst79 is offline
Default Re: Best Core 2 Series Desktops-Results and Specs
Posted some BIOS settings for the new builders hopefully it covers the basics
That's awesome sunburst Thanks. I think that's even helpful for experienced builders. I know I will use it as a checklist.
Well I hope everyone can decipher what I wrote and its legible and understandable. You and Mykhal going to test drive it for me. I kicked the tires.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
  #412
Old 11-29-2007, 09:28 AM
vocalvoodoo's Avatar
vocalvoodoo vocalvoodoo is offline
Default Re: My Build and Questions
Well, I'd probably but the Thermaltake again because I'm an overclock dork and can't stop. But for normal CPU clocking, I'd probably not get it again. Especially with the new G0 stepping as Sun mentioned. My Q6600 seems to run pretty hot though because it is a B2 stepping version.
The fans I'm running now are the Scythe NMB fans on both the back and top of the case and one of the 3 way switch fans that came with the case on the heatsink itself. When recording, I'll clock the case fans down with speedfan and switch the CPU fan to the lowest setting. I rarely use it anymore, but if you want specific temps, let me know and I'll fire it up.
I will say this, I was much happier with my e6600. Ran much cooler, and I only ran the fan that came with the Ninja, no case fans, and things stayed more than cool enough. I could hardly hear the fan running.
Did the Ninja fit in your Antec case with the fan mounted to it? It looks like I'm going to end up going with 3 1200 Noctuas for the case and 1 1200 Noctua for the Processor.
the Ninja fit just fine. I think it's actually a little shorter than the Thermaltke. It is a bit of a pain to mount though.
  #413
Old 11-30-2007, 04:39 PM
FatBelly FatBelly is offline
Default Re: Kensington Ultimate Tackballs
sunburst79 or anyone.
I was under the impression that the larger your graphics card memory was the less
your system memory gets taxed. Can anyone direct me to where I can research this.
I'm about to order my system and I'm hung up on the video card.
I'm currently planning to purchase this one.
Let me know what you think.
Thanks in advance
FatBelly Slim
Oh no, not the sprinklers again.
  #414
Old 12-01-2007, 02:39 PM
Willosy Willosy is offline
Video Cards that don't use technology like Turbo Cache (nVidia), I'm not sure what ATI call it, just use what ever RAM that have on-board.
Turbo Cache etc, are usually on low end cards with bugger all on-board memory. Specs don't mention use of system memory and with 512MB DDR3 on-board I doubt it would use system memory.
I must say though that this card is way overkill for a DAW.
  #415
Old 12-01-2007, 03:02 PM
Default My System
Hi Guys,
After starting my own thread, Sunburst suggested I post here so we have a record of my build to track successes and errors for everyones benefit. Here goes:-
Case :- Silverstone Temjin TJ-08 mATX (Excellent Case, Great Build and 120mm Fans)
PSU:- ThermalTake Pure Power 430W
Motherboard:- GA-965GM-DS2 (Gigabyte based on INtel 965G Chipset)
Firewire:- On-Board Firewire (VIA)
Memory:- 3GB or DDR2-667 (2 X 1GB Kingston Value RAM + 2 X 512GB Mushkin Value RAM)
Both Sets are dual channel kits to be run in Dual - Channel
CPU:- Intel® Core™2 Duo Desktop Processor E4300
CPU HeatSink:- Scythe Ninja Plus Rev. B Passively Cooled
Fans:- 2 X Artic Cooling 120mm PWM Fans. Connected to CPU PWM Controller High CFM and
Quiet. Automatically Spreed Adjusted By System Temp. 1 X Intake & 1 X Exhaust
Video:- nVidia 256MB 7600GS Passively Cooled
DVD-Burner:- Pioneer DVR-212 SATA
Hard Drives:- 1 X Samsung SpinPOint 250GB 7200RPM 8MB Cache - System Drive and Some Track Recording
1 X Maxtor 500GB 16MB Cache 7200RPM - Main Track Recording Drive
Build to start Tuesday. Will keep you posted.
  #416
Old 12-01-2007, 10:04 PM
Default Best Core 2 Specs
Thanks in advance
I used to think the same thing
A grossly simplified version is that once you have 3GB or more memory in the computer the system will set aside X amount of memory to "Feed" the cards. In my system with 4GB of RAM and a 256MB card I was showing 3.25 GB of RAM. When I dropped in a second identical 256MB video card the memory dropped to 3.00 GB even. If your going to run memory sizes over 3GB I would look for a 128MB card which is more than enough for Pro Tools.
If I understand the situation correctly this does not occour if you only have a total of 3GB or less, Only more than 3GB. I have not tested this personally though.
Strange but true.
If your running Vista and 4GB of RAM that 3.25 under XP drops to 3.12 according to Microsoft.
I would recomend you grab a 256mb or less video card.
It's looking like the original ASUS X1600 Silent video card specced in the top of Core 2 System Specs page is no longer going to be made. I am interested in the Radeon 2xxx series as a replacement. I may not be able to help you if you have video problems since I have a different card but I would be VERY interested in your results with a 2xxx card.
Scott
Core 2 Specs Page
  #417
Old 12-01-2007, 10:25 PM
Default Re: My System
Hi Guys,
Not seeing any problems with those specs. I'm not however familier with that board. If its got the VIA 6308 FW chip you should be aware its not working with Protools (or at least not on the ASUS boards) a Digi approved FW card solves the problem. There have been some reported issues with the Gigabyte boards with the P35 chipset and Samsung SATA2 drives-as far as I know the P965 is not affected by this. Just a general heads up.
Scott
Core 2 Specs Page
  #418
Hi Guys,
Scott
Core 2 Specs Page
  #419
Old 12-01-2007, 10:44 PM
Default I would like to say thanks for the Sticky
I would like to thank DIGI for the Sticky
All of the system builders here and in the Core 2 thread deserve a big hand for the effort thats made a untested and unqualified platform a success.
Hopefully the the sticky will eliminate all the crossposting across the forum regarding Core 2/Intel Systems.
And if the thread ever goes for more than a year without updating the top of the page please unsticky it and let it it die a natural death
Scott
Core 2 Specs Page
  #420
Old 12-01-2007, 11:09 PM
Shan's Avatar
Shan Shan is offline
Default Re: I would like to say thanks for the Sticky
About flippin' time! And congrats! Your email requests will now triple(trust me) and I can take a bit of a holiday for awhile until the 8-cores roll out.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
i7 Builds - Specs and Results mykhal c Windows 7144 Yesterday 12:10 PM
Intel Quad Core vs. i-series solidwalnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-23-2010 05:16 AM
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-12-2009 02:24 AM
are these specs ok? (low budget 2 core) korkman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-22-2008 02:44 AM
8 Core Mac Pro, Leopard and Windows results pasanta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-13-2008 06:51 PM
