Lost Pan Settings at End of Mix
This was frustrating. At the onset, I'll say that my pan settings were done "manually" using the virtual knobs, not via automation. Periodically and for my final mix, I bounce to one designated stereo mix track and my normal procedure for this involves using option-click on one output, which then sets all outputs to, say, Bus 15-16. This time, I accidentally selected a mono output and all the outputs changed to that AND set all pan knobs back to the default center position. The only was I could get my panning back was to "Revert to Last Saved". Not good enough. Is this a bug or do I have to be paranoid now when selecting my output?
Re: Lost Pan Settings at End of Mix
Not a bug. You routed everything to a mono output, so yes, all panners were gone.
Set auto-backup to every minute or two and you'll never lose anything important.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
I always hit cmnd-save before I do operations like that which are not undoable. That way I can just close it without saving and start over.
You might consider routing everything thru a aux track from the start. That way routing to a print track much easier and flexible. Also, plugins are post fader. I know many people do that. I always do. A bug? I don't think so. Selecting a mono bus as output will of course remove panning from a track. It could of course have been in the undo cue, but it's not. |
Another thing about master faders is that their inserts are post-fader. This is because you sometimes want to do bit-reduction and dithering on an output and you want that to happen after any change in volume on the fader. This makes it impractical when it comes to f.ex bus compression on master faders; if you touch the fader you also change the compression threshold. I like to control the compression in the plugin and just use the fader for volume. So, I started using an aux track as my master output. Its output is set to my main physical output, its input is a stereo bus to which everything is routed, plugins are pre-fader, otherwise it's just the same. I could have a master fader for the output also, but there is really no need. Another thing I find really practical about this is that I can quickly change the routing of this aux master, to f.ex print on a audio track. Something you can't do on a master fader. A master fader can't be routed anywhere. It's really just a controller for one physical output. Or I can set the output of my aux master to more than one destination (ctrl-select-ouput on mac), also very nice. |
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
You don’t really need to revert to “last saved”. Just save the Mix you’re working on (with a new name), and import the output s and pan data from the previous mix or last auto backed up mix.
www.chrisshawmix.com PT 20.3.0 S1 x2 Artist Transport Avid Control iPad 7th Gen HD Native Hackintosh i9 3.6 GHz Six Core MTRX Studio OSX 13.6.4 |
Session settings getting lost... | DigiDudeski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-19-2007 12:30 PM |
Plug In Settings - LOST | Sir Issac Waveski III | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-16-2005 04:50 PM |
Amplitube Settings Lost | thejewdrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-11-2004 08:08 PM |
Plug-In settings getting lost in DP | adair | Pro Tools TDM Systems (Mac) | 0 | 02-09-2000 10:45 AM |
D-FX Settings Still lost in 5.0! | imported_yes | Pro Tools TDM Systems (Mac) | 4 | 01-21-2000 10:48 AM |
