AAX VI's with Poly-AT
Using a Vax77 here, but with the qunexus and the CME xkeys out Poly-AT can now (finally) be a bit more of a household item. It really is such a great and intuitive way to create a lot of variation and motion inside chords.
Hopefully if this becomes more common, DAWs (including PT) will actually figure out a way to edit it! I think some sort of lane that changes based on what note is selected would probably get the job done...(the event list is hopeless). Anyway, wanted to start getting a list together. So far the only thing I can confirm for AAX is omnisphere/trillian. Anyone know of other AAX VI's with poly at? Alchemy 2 should be out soon-ish? Can anyone confirm U-HE stuff? If any devs are reading this, I MUCH prefer it when 'aftertouch' responds to both ch and key. It's a bummer when presets have to all be switched one by one from one to the other. |
poly wav files and PT 9 | allegrarc | macOS | 0 | 09-05-2013 06:31 AM |
Importing poly wav files in PT 8 | fonograf | Post - Surround - Video | 8 | 04-06-2011 10:01 AM |
Poly pressure message on PT 8 | Noziroc | MIDI | 2 | 12-16-2009 10:47 AM |
Xpand Poly/Mono | yamlan | Virtual Instruments | 5 | 05-03-2007 02:00 AM |
New Poly 800 Pluggo | The Lone Roger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-23-2004 08:02 AM |
