Old 06-23-2017, 02:56 PM
EddieJones's Avatar
Default Eucontrol v3.6.1 Now Avialable
Avid is pleased to announce the release of EuControl/Workstation software version 3.6.1 for the S3, Dock, Pro Tools|Control, and Artist Series. Log in to your Avid Account (for S3, Dock, and Pro Tools | Control) or My Artist portal to download the new software.
All EuControl Devices / EuControl Software
• Over 10 conditions which previously could crash EuControl no longer do so.
• It could be difficult for some plug-in knobs to reach their maximum and minimum values
• Resetting Send level via Opt (Mac)/Alt (Windows)+touching a knob would reset it to –Inf/off instead of 0/unity
• Navigating to Send/bus pan by pressing a Send knob could reset/clear Send level
• EQ 3 Mid band control would not always switch to Q when Sel was pressed
• It was possible for Wheel Modes and other functions to not be able to be assigned to Soft Keys on Mac
• The EuControl Soft Key Editor now stays focused on the currently locked-to Application
• The Workstation tab now uses a checkmark instead of an X
Pro Tools | Control
• Changing Automation mode via "Do to Sel" required two presses of the desired Automation
• mode button
• Mixer view would reset to the first 8 tracks when toggling between applications
Pro Tools | Dock
• The ALT switch sometimes needed convincing before allowing you to enter Preview mode
Pro Tools | S3
• The Audio Control encoders (9–16) could exhibit delayed response when adjusting built-in I/O
Note: Requires new S3 firmware provided in EuControl 3.6.1.
Artist Series
• Artist Transport: It was possible for the Soft Key to Restore Previously Shown Tracks to stop working
Note: This fix requires Pro Tools 12.8 or higher.
• Artist Transport: Several Shift layer Soft Keys on the numeric keypad that required a Wheel mode no longer worked
Please note the following:
Make sure control surface firmware is up to date after installing EuControl 3.6.1
A new version of Pro Tools | Control (v3.6.1) is available on the Apple App Store
Eucontrol v3.6.1 Now Avialable EddieJones Avid S1, S3, Dock and Control App 19 09-14-2017 09:33 AM
Eucontrol v3.6.1 Now Avialable EddieJones Artist Series 5 07-22-2017 12:43 AM
Eucontrol v3.6.1 Now Avialable EddieJones Avid S1, S3, Dock and Control App 0 06-23-2017 02:56 PM
EuControl 3.4 mbryan67 Avid S1, S3, Dock and Control App 5 05-27-2016 02:23 PM
EuControl Trazan Artist Series 3 12-13-2011 12:57 PM
