  #41
Old Today, 02:22 PM
Default Re: Sod it buying a Mac now
Originally Posted by Raoul23 View Post
I’ll be using the PE6R4 chassis with them that’s PCIe
But that's still something you have to take into account. Will the adapter card work in the MacPro you're looking at?
See profile for system details (note change to a new system Oct.7 2017)
  #42
Old Today, 02:24 PM
Raoul23 Raoul23 is offline
This is were I’m absolutely confused with macs. A 4.1 mac has PCIe slots am I right?? So the adapter card should fit right
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 7, Windows 7 64 Bit, I7 960, Supermicro X8SAX, NVIDIA GeForce GT 610, 12GB Ram, Magma P7R464, Kingston SSD, 2 X WD Caviar Black, Dual Monitors
  #43
Old Today, 02:34 PM
YYR123's Avatar
YYR123 YYR123 is online now
How come the 2nd one is better, even though the 1st has 2x3.0 processors and the 2nd only has 2x2.8
This is a good ref website.
https://www.cpubenchmark.net/
The 2.1 machine Xeon 5365
https://www.cpubenchmark.net/cpu_loo....00GHz&id=1295
The 3.1 Machine Xeon E5462
https://www.cpubenchmark.net/cpu.php....80GHz&id=1237
So the direct compare seems to indicate the systems are pretty similar as far as the CPU's
https://www.cpubenchmark.net/compare.php?cmp[]=1237&cmp[]=1295
So the 2.1 and the 3.1 both register about 4k on the CPU power rating.
The 4.1 specs about 9600....so that is the extra power that the different generations will give you.
That is the power that will be the foundation for running pro tools and you will feel the difference.
You may be able to run the system with a 2.1 but what happens if it doesn't? Then you have to get another....spend all you can and the Mac experience will not let you down.
Daniel
HD|N - PT12.5.1 - HD I/O 16x8x8
Win10-Pro - 6 Core i7-6850k - ASUS X99 Deluxe ii
For the Love of everything sacrosanct and hallowed, Why hasn't track presets been implemented yet? - George Jetson
For the Love of everything sacrosanct and hallowed, Why hasn't track presets been implemented yet? - George Jefferson
For the Love of everything sacrosanct and hallowed, Why hasn't track presets been implemented yet? - George Clinton
  #44
Old Today, 02:35 PM
YYR123's Avatar
yes 3.1 and newer all have the PCI-e slots and they will physically fit into the slots.
Daniel
  #45
Old Today, 02:36 PM
It has four - two 4 lane pcie2.0 slots and two 16 lane pcie2.0 slots. It's up to you to find out if your adapter card will work with those slots.
  #46
Old Today, 02:38 PM
So 4.1 will run OSX lion which according to research is the best OS for pro tools 10HD and TDM cards
Raoul Crane
  #47
Old Today, 02:41 PM
Agreed. Get into it in the right way and you won't be disappointed. There's no need to spend big bucks but also there's no need to cheap out either. Don't think about the minimum of what PT will run on as that will only make you wonder why you went down that road. I could have gone really cheap with the MacPro 5,1 I just got to replace the iMac I was using before it's video card fried itself but decided it wasn't worth the aggravation.
  #48
Old Today, 02:47 PM
This is the adapter from the chassis
Raoul Crane
  #49
Old Today, 02:50 PM
No problem. Actually a 4,1 will run High Sierra but with PT10 that's not something you have to think about. PT10.3.10 (the last revision) runs very well on OSX 10.8.5
  #50
Old Today, 03:36 PM
YYR123's Avatar
All the following are opinions but based on personal experience.
I would much rather use 10.6.8 than 10.7.x
I would much rather use 10.8.5 than 10.6.8
I used PT10 HD on the 10.8.5 machine and it worked great....Disk Cache was so awesome on that machine....really helped.
Daniel
Buying a new Mac. xtratorque Pro Tools Software (Mac) 39 11-08-2013 02:43 PM
Need help buying a mac fohryan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-23-2005 10:36 PM
buying a new mac kds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-21-2004 04:53 PM
Buying A. Simon General Discussion 2 09-29-2003 07:37 PM
HELP! I am buying a Dell Laptop with intent on buying a DIGI 001 as well xian$ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-18-2003 12:53 PM
