Old 10-10-2017, 12:24 PM
SebDollar SebDollar is offline
Default Major Issue - Midi via USB is broken for no apparent reason - ProTools 10.3.9 OS X
Hello All,
I really hope that some of you kind people can help me with this! I have tried everything i can think of, and google can't help me either.
From day to day, suddenly absolutely nothing happened when i played on both my Keystation49 keyboard or MPD226 - both connected via USB. It had worked fine on my current setup for over a year, and i haven't updated anything or installed any new programs or plugins. As i restarted my computer, i got the following error while booting Pro Tools: "The original MIDI device associated wwith the MIDI controller "MBox3" could not be located. Please choose an existing MIDI device in the MIDI controller section of the peripherals dialog.".
Two weird things about this is that i don't have an MBox3 plugged in, but rather an MBox3 PRO. I did have the drivers for the Mbox 3 installed at the time, but i have uninstalled it, and that didn't help and the same error appears. The second weird thing is that the error will only show the first time i open Pro Tools after i reboot, and then it will only be around half the times it shows even then.
Other symptoms are that the MIDI input selector (pictured below) will hang the entire program when i press it for 1-2 seconds and then hang again when ever i chose something. Both my devices shows up here, and in the MIDI/Input Devices menu, so Pro Tools does detect them.
Lastly, when ever i boot protools, the buttons to change octaces on my Keysatations become unresponsive. Not sure how relevant that is though.
My setup is Mac OS X 10.8.5 with Pro Tools 10.3.9 and with an Mbox 3 Pro.
So far i have tried (in this order);
Trying different USB ports with no USB hub connected
Borrowing other midi devices, none work
Midi Thru is set, all options set to none under peripherals, midi controllers
Trashing Pro Tools Preferences and Database
Uninstalling Mbox 3 drivers (as i don't use it)
Uninstalling and Reinstalling Mbox 3 Pro drivers
Uninstalling and Reinstalling Pro Tools
Fixing Disc permissions with Disc Utilities
Currently I am at a loss, so i really hope out there has the answer.
Regards,
Sebastian
Old 10-10-2017, 12:47 PM
Default Re: Major Issue - Midi via USB is broken for no apparent reason - ProTools 10.3.9 OS
Update - As i have a PT11 license as well, i just tried downloading that, and it has the same issue
Old 10-13-2017, 11:26 AM
DonaldM's Avatar
DonaldM DonaldM is offline
I'm not a Mac person, but I noticed you said you uninstalled the MBox3 driver. Did you re-install the MBox3 Pro driver? You need a driver installed for whatever interface you're using. If you have access to another audio interface, you might try installing it and seeing if that works. If it does, then you'll know its likely an issue with the MBox3 Pro.
"Rule number one in music is there are no rules in music! Rule number two is see rule number one!" Armin Van Buuren
Owner: Dragon Rock Productions
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 12.7
Interface: Focusrite Scarlett 8i6
JBL LSR4326 Monitors
Yamaha Motif XS8
Reason 9.2
PTIEP 2.0
Spectrasonics Omnishpere 2.0
East West Libraries
Nexus2
Xfer Serum
Synapse Audio Dune 2
and 30+ other VI's of various sorts!
Old 10-13-2017, 04:09 PM
Top Jimmy's Avatar
It sounds more like the OS is having issues since CoreMIDI handles the MIDI stuff. I'd reformat the boot drive and reinstall Mountain Lion.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.2.
Pro Tools HD 12.8.1, Mbox3, MOTU PCI-424 w/ 2408mkII & 1224 (Mac)
Pro Tools 11.3.2, Mbox2, Focusrite Scarlett 18I8 (Win 7)
Protools 10 audio outputs stopped working for no apparent reason Cryos Pro Tools 10 Discussion 6 04-03-2012 04:13 PM
Pro Tools 8.0.sc3 Crashes for no apparent reason! robinbjerke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-04-2010 04:59 PM
-9073, for no apparent reason! Yay! ReclusEndangrmnt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 07-10-2009 11:05 PM
Digi002 peaks for no apparent reason GreenHat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-28-2007 06:17 AM
Mbox shutting down for no apparent reason voysit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-13-2005 01:54 PM
