  #41
Old 01-25-2015, 10:22 AM
nigelpry's Avatar
nigelpry nigelpry is offline
Default Re: PT12 has less Instrument Tracks?
Originally Posted by studioj11 View Post
Perhaps now there is going to be a direct upgrade path to HD? ...without buying hardware, or maybe features will be avail a la carte. I suppose in that case further restrictions of the entry level version might make sense business wise. And if the added features aren't cost prohibitive, it could be a good thing overall.
I'll have some of whatever you're smoking ;-)
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10
iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6
Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors.
Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
  #42
Old 01-25-2015, 10:48 AM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Originally Posted by adgjk View Post
Does PT12 really have less instrument tracks than PT11, or is this just a typo in the chart?
(Compared to the PT11 chart)
The number of instrument tracks has been halved for both Pro Tools and Pro Tools HD.
Can anyone shine any light on this?
Thanks
I have confirmation that the Instruments Tracks listings are a typo which will hopefully get corrected asap.
Pro Tools 12 and Pro Tools HD 12 will have the same Instrument Track numbers as Pro Tools 11, when they were doubled from the number in Pro Tools 10.
This is from the What’s New in Pro Tools 11.pdf...
Increased Instrument Track Count
Pro Tools 11 supports up to 128 Instrument tracks.
Pro Tools HD 11 supports up to 256 Instrument tracks.
Same numbers in Pro Tools 12.
Bruce Paine
System Details
  #43
Old 01-25-2015, 10:59 AM
Rufio Rufio is offline
I would just like to chime in and mention that there is some precedence for these kinds of typos. I found a very similar typo for PT10:
http://duc.avid.com/showthread.php?t=333081
  #44
Old 01-25-2015, 11:06 AM
Thank you, thank you and thank you for this info.
Jack
QAPLA!
  #45
Old 01-25-2015, 11:39 AM
adgjk adgjk is offline
Great news! Now to deal with the cloud storage and monthly payments...
  #46
Old 01-25-2015, 01:51 PM
deanrichard deanrichard is offline
A "typo"? I'm suspicious.
More likely that marketing decision was quickly reversed after the negative feedback it generated. I'm sure that within the PT application code changing the number of instrument tracks is simply changing a configuration setting that controls the maximum number of tracks. So for a developer it's literally a 2-second code change. Marketing says make it 128 again. Change the number 64 in the config file to 128. Done.
Dean
  #47
Old 01-25-2015, 02:05 PM
Southsidemusic's Avatar
Dean
Come on
Why in hell would Avid do this on purpose? Do you think that they don't have more inportant issues to deal with than secretly planning this rediculous conspiracy theorie of yours?
Everything is not conspiracies and people at Avid are human beings and as clearly documented everywhere humans make mistakes and correct accordingly. Its just life!
Just wait until EVERYTHING is clear and release notes inplace instead of making such a HUGE issue of every detail you find "odd"
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #48
Old 01-25-2015, 03:35 PM
Drew Mazurek's Avatar
If this were the case, then Avid would have made it so Pro Control and Control 24 would work in 11.
Seriously, it seems they do what they want do and can weather whatever storm it brings. That's been the recent history.
www.drewmazurek.com
  #49
Old 01-25-2015, 03:41 PM
Oliver M Oliver M is offline
L O L, you are so wrong!
Pro Tools FAQ is now updated for PT12, etc. nst7 Pro Tools 11 120 01-25-2015 01:08 PM
2 instrument tracks each controlled by different MIDI input/instrument Midimax Pro Tools M-Powered (Win) 0 03-20-2012 03:10 PM
Applying Instrument Tracks to Reg. Audio Tracks d00m1001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-13-2009 08:55 PM
MIDI Tracks Versus Instrument Tracks. VERY Confused. Rick540 MIDI 8 12-04-2008 11:04 AM
No Instrument Insert on Instrument tracks Bazbo Virtual Instruments 4 03-01-2007 06:00 AM
