Maximum peak level for a movie comercial?
Hello
I´m mixing a comercial in stereo for a movie theater which complyes with Dolby standart. I´d like to know what is the recomended maximum peak level I should deliver in the mix. Thanks, this is my first time mixing for movies. |
Re: Maximum peak level for a movie comercial?
No such thing. However, you must meet 82 dBleq(m). Then again, if it's stereo, it must be some sort of festival or special thingy because usually a 5.1 is required (Cinema was never (2 channel) stereo), and they probably don't even care.
You should really try and get a spec. sheet from your client, but for example "Screenvision" ask for a stereo broadcast mix peaking no higher than -20db.
Richard Spooner Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM. www.spoonsound.com |
Actually … my spec. sheet is now out of date … "Screenvision' now says stereo broadcast mix peaking at -10dfs
http://www.screenvision.com/wp-conte...Specs_2013.pdf
I mixed a cinema spot that was being trafficked through NCM last week. Spec for them was -10 peak and -24lufs. With 5.1 discrete, PL2 or stereo files on a quicktime.
True stereo; LoRo, fed to Left and Right only in a theater sounds awful.
An LtRt "broadcast" mix or decoded LoRo is a close second, with hyper compressed/limited/EQ'd VO tracks contributing to the awful factor. j |
Squeezing Maximum Level out of MP3's | Hank5 | Pro Tools TDM Systems (Mac) | 3 | 05-01-2006 02:00 AM |
DVD Peak Level | Andy Hay | Post - Surround - Video | 3 | 04-17-2005 11:35 AM |
maximum quicktime movie length? | inscapesound | Tips & Tricks | 5 | 09-30-2000 12:18 AM |
maximum quicktime movie length | inscapesound | Post - Surround - Video | 2 | 12-20-1999 11:09 AM |
maximum quicktime movie length | inscapesound | Tips & Tricks | 0 | 12-16-1999 07:28 PM |
