#101
Re: PT 7.3.1 - Still Features Random Graphic Freez
I experienced one of these freezes last night (screen graphics freeze, session still plays, able to stop and start, no spinning beach ball). During the freeze I tried to Quit Pro Tools. When I did this I got a message telling me that the task manager had incomplete tasks. I looked at the task manager and it said it was "synchronizing" the .ptf file from that session.
Not sure how or if this relates, but I thought I would pass along the information. This was on PT 7.3. |
#102
PT7.1, HD3 not Accel, G5 dual 2.5, Mac OS10.4.3
1) Cannot start or stop transport from the spacebar - TRUE 2) Cannot start or stop transport from a control surface (state which one) N/A 3) MIDI sequences stop playing - TRUE (played for a while at the beginning of the freeze then stopped) 4) Cannot manually play a virtual instrument during freeze - TRUE (played for a while at the beginning of the freeze then stopped) 5) Plug-in automation ceases to play during freeze - DON'T KNOW 6) Direct 9-pin device control from control surface ceases during freeze - DON'T KNOW 7) Mute automation ceases to play during freeze - DON'T KNOW 8) Volume automation ceases to play during freeze - DON'T KNOW 9) Surround pan automation ceases to play during freeze - DON'T KNOW 10) Your symptom here - When I had the freeze in the PT 6.9 era I could press stop and the transport would stop and the screen freeze would end. Doesn't seem to work anymore with PT 7.1. If I press too many keys or clicks during the screen freeze I get the SWOD. |
#103
During the GUI freeze (no beachball), the following occurs -
1) Cannot start or stop transport from the spacebar - TRUE 2) Cannot start or stop transport from a control surface (state which one) - N/A 3) MIDI sequences stop playing - TRUE (plays for a while, then stops. Reminds me somewhat of the old MIDI overflow.) 4) Cannot manually play a virtual instrument during freeze - TRUE (can play a few seconds, then it cuts off) 5) Plug-in automation ceases to play during freeze - N/A 6) Direct 9-pin device control from control surface ceases during freeze - N/A 7) Mute automation ceases to play during freeze - N/A 8) Volume automation ceases to play during freeze - N/A 9) Surround pan automation ceases to play during freeze - N/A 10) Your symptom here
#104
Looks like we are treading water with this!!!
For now we'll have to deal with it!!! Apparently it's just a few users with this problem and isn't on top of the to do list!!!! Either we're doing something wrong or all the other users don't use their gear much or they have come to just deal with this.......
The Greatest Risk in Life is Doing Nothing |
#105
I think i managed to get a shark time profie during the freeze! i have just missed it a few times, but i think i got the end of this one!!. it did make PT go a it strange during the shark reading and i got an error 9162 and had to reboot PT. Would you like me to send it somewhere? Chris
#106
To Danny;
each time I experienced a freeze I went to check for modified files on my system. One file that always seem to match the exact time of the freeze is this file: WaveCache.wfm which protools obviously creates within the session folder.... Now I dont know whether this could be anything to you but I thought I'D report it nevertheless By the way my WaveCache.wfm is huge - it's about 25 Megabytes - is that normal?
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
#107
we're seeing that here on multiple systems as well. happens say 1 time every 10 mins. The systems are chasing Serial time code and using transport = machine so when in play and you hit stop/RW, nothing happens till the freeze goes away.
#108
2) Cannot start or stop transport from a control surface (state which one) True. Keyboard 3) MIDI sequences stop playing. Don't use Midi 4) Cannot manually play a virtual instrument during freeze Don't use Virtual instruments 5) Plug-in automation ceases to play during freeze True 6) Direct 9-pin device control from control surface ceases during freeze Don't use 9-pin 7) Mute automation ceases to play during freeze True 8) Volume automation ceases to play during freeze True 9) Surround pan automation ceases to play during freeze Don't use Surround 10) Your symptom here While recording or playing back, screen occasionally freezes for 4 to 5 seconds on both G5 dual 2,7 sattions, both HD3 (1 Accel, 1 Process). No crash follows and all goes back to normal afterwards. |
#109
So - I am sure that I have found ONE culprit for the freezes
I have set my apple watch to show seconds. Now, if I happen to be doing any editing in plug-ins or hitting play or record in the interim of protools doing an auto backup - the freeze happens. With every freeze I watched my exact time and it ALWAYS corresponds to when the session file was backed up. I am not sure this is the only thing causing the freezes but this is no coincidence. The time matches EACH n EVERY time Just thought I'd report that 25
#110
I have been getting these random freezes as well and I don't have Auto-backup on.
Mixing in the box, requires thinking outside the box. My New Instructional Mixing DVD 2 is Shipping www.tonysound.com http://twitter.com/tonysound |
I'm getting Graphic Freezes Again after MDW 3.0 | 25ghosts | Pro Tools TDM Systems (Mac) | 32 | 12-06-2009 09:47 AM |
Random Graphic Characters in Audio Regions - PT TDM 6.2.3 | ChrisMitchell | Pro Tools TDM Systems (Mac) | 4 | 05-21-2008 11:25 AM |
graphic freezes in mixer and edit windows | nincompoop | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 02-08-2007 12:36 AM |
7.3 Graphic Freezes | 25ghosts | Pro Tools TDM Systems (Mac) | 5 | 12-29-2006 04:03 PM |
graphic freezes | janrudi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-25-2001 01:57 AM |
