Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 06-08-2020, 02:28 AM
diane_son diane_son is offline
Default BUG Do To All gets stucked
Hi everyone,
I have an issue since some versions (2019 at least) with the ‘do to all’ soft key on S6.
Let’s say I have a macro SK with ‘do to all’ + ‘latch’ on DAW 1. A lot of times when I press the ‘solo’ or ‘mute’ or ‘bypass insert j’, etc, on the surface (from a soft key or directly on the strip), there is a bug where it applies on ALL strips of DAW 1. When I delete the ‘do to all’ soft key in the macro, it never occurs again.
This ‘do to all’ soft key which has nothing to do with any function except the one it is with (for example here ‘latch’) is applied to everything on the DAW ! You have to go back to your keyboard and mouse and manually de-solo every strip on the DAW, it doesn’t work if you do it from the surface with ‘alt’+’solo’ on a strip.
It is very annoying and dangerous. Could you please help me with this ?
S6 M40 WS2020.5 PT2020.5 OSX10.15.3
Thanks a lot
Old 06-09-2020, 06:56 AM
bucha bucha is offline
Default Re: BUG Do To All gets stucked
Same for me here since the 19.5 version.
Very annoying for all my "Do To All+ …" macros !!
Can't install ProTools 8 - totally stucked - help needed luffe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-05-2009 04:06 PM
7.4.2 on OS 10.5 - "creating dae objects" stucked rolphee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 12-16-2008 04:43 PM
MIDI Merge function causing stucked notes SoundReplay Pro Tools TDM Systems (Mac) 0 07-26-2006 08:23 AM
Stucked at %14 when install.... King Kong Digidesign Hardware & Software 0 09-21-2001 11:30 AM
