The "less pro" audio delay buggy
Ok, this is pretty common on my system and it frequently makes me look not so "pro"...
Typicaly, I record on a track with delay comp on (compensating the other tracks with plugins etc). When I make a duplicate this track and rec-arm it theres a audible delay. Sometimes turning delay-comp off and on will do the trick - sometimes not. I see these things a lot. It's been like this for a long time. Anyone seeing it too? Boe |
Re: The "less pro" audio delay buggy
Yes, think i've posted before on this. HDX rig, my workflow similarly involves duplicating tracks to record on for vocalist etc. Not every time but enough to not give me confidence , crazy i know on a 5k system.
This problem is why just tracked a whole album of vocals on the old TDM system. The reproducibility of this bug is a problem in being able to show it to Avid although others have had similar. |
yes i encounter this often when overdubbing. it's a total glitch and there's no fix that i'm aware of. there's not even a reliable way to de-bug it as far as i know... i've had limited luck toggling ADC off and on (sometimes 3-4 times, lol), so usually just end up restarting protools to save time.
can you imagine paying 10k for any other THING and seeing basic stuff like this not working!? |
@wildhoneymusic http://kidzbop.com/music/ https://concord.com/publishing-roster/gary-philips/ |
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
i never had this problem on my TDM rig, or any other studio i worked in with a TDM system!
between a rock and a hard place unfortunately, since DSP plugs are so few and far between (comparatively to the TDM options in the past).
kill ADC with any native processing going on elsewhere in the session and it's worse. even though ADC sucks with native on HDX, at least it's getting you closer... |
Def happens on TDM as well. Just last week on an HD6 system running 10.3.9 HD. The engineer and I spoke about it extensively. They've had avid over there to look, but still no fixes.
The fix is time travel. You would have to sing early by the delay comp amount. How do other DAW's handle this?
That's just not true -- most of the time it works fine and the singer hears himself normally. And then occasionally what he's hearing back is somehow delayed, at which point you need to de-activate and re-activate the track. That's the bug we're all describing.
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
"unable to parse audio file" and "OSStatus Error -208" ! | reichman | Post - Surround - Video | 2 | 03-22-2010 04:46 AM |
PT 8.1 audio "hits" or "pops" when i open files from PT7... | djoeyd77 | Pro Tools TDM Systems (Mac) | 1 | 10-31-2009 03:59 AM |
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... | leon777 | Pro Tools TDM Systems (Mac) | 21 | 10-15-2002 12:00 AM |
