help with PC neuendo to Mac PT session
I have a session coming in saturday that has been recorded on a PC using Neuendo. I'm using PT 6.4 on a Mac. The session will be on an EZ Swap serial ATA drive. they will not be bringing the caddie just 80 gigs on a serial ATA drive. the session is in broadcast WAV files It's a live recording so all tracks will start at the same point. there for I don't need a session map I just need to get the WAV files off the PC based drive and into my Mac based PT system. Any suggestions on how to do this? and what equipment I will need?
thanks Electrok |
Re: help with PC neuendo to Mac PT session
Pro Tools and a drive which accepts the caddy the hard drive is mounted in. Simply Spot the BWF files. You don't mention which OS you're running, so I'll assume you have Panther which can read NTFS formatted drives. If they're bringing a bare drive.. we'd have to know which Mac you have and how many IDE devices are already installed.
Rail
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 | doubtful guest | Pro Tools TDM Systems (Mac) | 1 | 02-06-2013 03:42 AM |
Vacuum patch gets shorter decay time at 96kHz session than 192kHz session | chrisdee | Virtual Instruments | 21 | 10-07-2011 10:02 AM |
End of Stream Reached - session broken - import session data does not work... | Sean Russell | Pro Tools TDM Systems (Mac) | 0 | 01-15-2010 04:56 PM |
Neuendo>OMF2>Digitranslator | drenched | Post - Surround - Video | 3 | 08-18-2001 05:14 PM |
Neuendo>OMF2>Digitranslator | drenched | Post - Surround - Video | 0 | 08-11-2001 07:17 PM |
