Old 04-06-2020, 01:17 AM
noiseboyuk noiseboyuk is offline
Default EuControl 20.1.0.50 problems with Artist Mix
Had a brand new problem this morning with 20.1.0.50 and the Artist Mix on Win 10 Pro. The surface connected to the computer and had added itself under My Surfaces ok, but wouldn't communicate with PT 2020.3. EuCon was enabled in PT. I disabled and re-enabled it, power cycled the Mix, removed the surface several times all to no avail. I then stopped the services in Task Manager, and ran MC Client and EuControl as Administrator, and finally it took.
Never had these symptoms before, all my issues historically have been that the unit won't be found under All Surfaces. This time it found it ok but couldn't communicate with PT.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2020 Ultimate; W10 Pro; i7 7820X; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Old 04-07-2020, 10:29 AM
EddieJones's Avatar
Default Re: EuControl 20.1.0.50 problems with Artist Mix
This could happen if something network related changed whilst EuControl was running. Driver updated, Wifi turned on/off, VPN...the list is long. A restart of the PC probably would have fixed it too.
Download Artist Mix Firmware from Eucontrol 18.3? sjgam Artist Series 2 10-11-2018 04:56 PM
EuControl 3.6 crashing when Artist Mix connects reeltime@mac.com Artist Series 10 06-02-2017 01:32 PM
Eucontrol 3.6.0 Firmware 1.5.4 (Artist Mix) Not Working Oady Artist Series 10 05-27-2017 05:19 AM
Artist Mix not appearing in EuControl JakeHa Artist Series 0 07-22-2016 04:39 PM
EuControl v3.2.2 for Artist and S3 Now Available Avid Technical Alerts 0 04-03-2015 07:23 PM
