Old 01-09-2011, 08:13 PM
bvirkler bvirkler is offline
Default Switch a track to playlist view from D-Command
I know how to switch a track to volume, pan, mute, and waveform views using Ctrl + command + touch, but how do I get to playlist view from the D-Command?
(Cross-posted from http://audio.stackexchange.com/q/536/64)
Old 01-10-2011, 05:44 AM
Soundtrack Soundtrack is offline
Default Re: Switch a track to playlist view from D-Command
Not sure for D-command but on D-Control we use the Playlist buttons in the Soft Keys. (Previous and Next Playlist buttons)
Remember to put a track in Focus Mode, for changing the Playlist to Previous or Next, or to New/Duplicate the Playlist.
Grz,
Louis
Old 01-11-2011, 02:30 PM
macaholic macaholic is offline
Ctrl + cmd + select button on the D-Command channel you want.
JC Richardson C.A.S.
Magick Lantern
Atlanta
Old 01-11-2011, 02:32 PM
I thought that put the track in waveform view? Anyway, I have a session this evening, I'll give it a try.
Old 01-11-2011, 04:35 PM
Hanswurstlsepp Hanswurstlsepp is offline
Afaik that's not possible with D-Command to set the selected track within the EditWindow to full and opened playlist-view (Tracklane View).
I think this is what u wanted ?
See also this thread:
http://duc.avid.com/showthread.php?t...light=playlist
Cmnd/ctrl & Select switches whatever view back to waveform.
Within the Playlist SoftKeys you can just switch the active playlist by using "PrevsPlylst" and "Next Plylst" buttons.
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 01-11-2011, 06:35 PM
That's exactly what I wanted. Thanks for the answer, even though it wasn't the one I wanted
Old 01-12-2011, 08:06 AM
Yes. I would like to have it too.
Cheers, STeff
New playlist view buggy Tunekicker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-19-2010 11:50 PM
Bug in playlist view mrjohn Pro Tools TDM Systems (Mac) 1 01-28-2010 10:45 AM
Still fighting with track heights in Playlist View KingFish Pro Tools TDM Systems (Mac) 1 03-19-2009 07:13 AM
Make playlist into own track command? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-12-2009 01:36 PM
Playlist View Track Height Chaos PTLE 8 KingFish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-22-2008 10:57 PM
