Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 07-23-2021, 07:12 PM
Coryo Coryo is offline
Default Pro Tools First PXF PlugIn Error Message
Hello,
For the last couple of weeks I haven't been able to access any of my projects on Pro Tools First. I receive this message: "Could not create a new document because PXF PlugIn is not installed"(see attached image). I have tried the following remedies with no success:
- Uninstalled and reinstalled the newest version of the program
- Changed around setup settings
- Moved PlugIn files into a different folder, and then back
- Looked up PXF PlugIn(haven't found anything to download)
- Looked into third party plugins as an issue(I do not have any third party pluging to my knowledge).
Anyone have any suggestions? I've been paying for the cloud service for a while now, so being unable to access my projects is pretty frustrating.
File Type: jpg 218622003_10222411388526857_3347295854176870163_n.jpg (8.4 KB, 0 views)
Old 07-24-2021, 07:35 AM
Default Re: Pro Tools First PXF PlugIn Error Message
Hmm, never seen this issue before. I would remove and re-install PTF(it won't affect sessions of projects). Personally, I would avoid the cloud and work only with "sessions" on your hard drive(instead of "projects" in the cloud). Check the manual to see if you can download or copy cloud projects to your hard drive.
Old 07-28-2021, 09:31 PM
mongsoup mongsoup is offline
I have this same exact issue, have you found a solution?
Old 08-05-2021, 12:21 AM
Update.... Still nothing. I actually bought a new computer, partly because I was desperate to get this working and collaborate with my band. When trying to open or create a new project I just get a blank screen now.
Anyone have any idea what I can do? I'm just so frustrated and out of solutions. Is Pro Tools really this terrible?
Old 08-05-2021, 07:21 AM
DigiTechSupt's Avatar
Originally Posted by Coryo View Post
Hello,
Try going to your plugins folder then temporarily place all plugins on a different location, then launch Pro tools first and see if the same issue occurs. C:\Program Files\Common Files\Avid\Audio\Plug-Ins
-Tope
Avid Audio Tech Support
Support FAQ
Old 08-05-2021, 07:22 AM
Can you post a screenshot? Not sure if it's just the mix window not appearing, you can try hitting CTRL+"=" on windows / CMD+"=" on mac.
-Tope
Support FAQ
Old 10-13-2021, 10:26 AM
JimiD JimiD is offline
I am having the same issue. I opened a help case (#04266457). Avid support told me to search the Knowledge base. I didn't find anything helpful.
Old 10-13-2021, 01:13 PM
junkgear's Avatar
junkgear junkgear is online now
Are you running under the same user account as you installed Pro Tools First under? If Pro Tools First can't access the project cache location on your disk, it can lead to similar problems.
Same goes for if you recently switched or added accounts to your system.
Will
System Details
what does this error message mean other than I can't use my Pro Tools? shockadd Pro Tools 11 1 10-12-2015 04:00 PM
Pro Tools 11 activation error-licensing service not running error message Seismic Sound Windows 5 03-23-2015 05:35 AM
Plugin Error Message mfhorn63 Pro Tools 11 7 02-04-2015 12:34 PM
TDM Plugin not Found, -7 Error Message Reatsch Windows 15 05-28-2013 10:26 AM
Error message in pro-tools sck312 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-06-2003 07:16 AM
