Midi Issue
Hi all.
I'm trying to set up a session so I can send Midi Control Programme Changes to my Rocktron Guitar Preamp Rack Unit for live applications. When I click with the pencil to add a programme change I keep getting this dialogue box (see attached) As I'm not overly savvy with Midi, could anyone the tell me how to actually correct this?. Last year I set up a previous session doing the exact the same thing with no issue?. A bit confused as to why it's doing this now?. Many thanks for any help offered Best Pete |
Re: Midi Issue
Has something changed in your Audio MIDI Setup (the Apple app in Utilities folder)
Re: Midi Issue
Hi there.
Thanks for responding. As to your question. I couldn't possibly say?. How do I check what you've suggested and what am I looking for ?. Many thanks Pete |
Re: Midi Issue
Your MIDI gear should be set up there first
Re: Midi Issue
Like this?.
Is that correct?. |
Re: Midi Issue
Window / Show MIDI Studio, set your MIDI there
Re: Midi Issue
Re: Midi Issue
no, you still have the wrong window. midi window looks different, it shows your midi configuration
Re: Midi Issue
But look, When I go to "Window" there isn't an option called "Show Midi Studio"
Re: Midi Issue
It is in the Audio MIDI Setup app you already had open. Have it active (it says which application is active right next to Apple logo on menu bar) and then click on the Window menu
MIDI problem - Midi Studio Issue | Microphone33 | MIDI | 4 | 02-27-2016 11:49 AM |
MIDI problem - Midi Studio Issue | Microphone33 | Virtual Instruments | 0 | 02-07-2016 02:09 PM |
midi issue- can see midi signal but cant's control Xpand2 | macroniche | Pro Tools 10 | 1 | 08-02-2012 12:16 AM |
Sync issue, pro tools MIDI and MIDI controller, timing issue | Angelo of Onello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-29-2011 07:57 AM |
Issue When running Midi and more than one Midi Track | amayhem | MIDI | 11 | 11-05-2009 06:52 PM |
