Songwriting & recording on the road
Hi there.
I'm looking for a way to utilize my iPad and Axiom MIDI keyboard when away from my studio. I'm thinking an app with built-in VI sounds, and audio (mic) and MIDI I/O compatible with the iPad. I would love to have the option to plug in 2 headsets/earbuds, but that may be a stretch. Any suggestions? Thanks.
Re: Songwriting & recording on the road
Are you looking for advice on an interface to take on the road, or for software to record music while away from your studio? What connections (ports) does the ipad have?
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
Well, I'm looking for a combo. I would prefer to be able to take my iPad with decent software installed, some sort of I/O "gadget", a mic and the Axiom with me. The goal is to, as a keyboardist, to write and record songs easily when I'm away.
The iPad has a Lightning connector, and the regular mic in and L/R out 3.5mm jack.
I don't know much about Apple products, never having owned any of them. The Focusrite Scarlett 2i4 is a nice portable interface, with mic and line inputs, plus midi in and out ports. Does the Axiom have a standard midi port or is it usb? Would a Lightning to USB cable work with your ipad? (The Scarlett connects to the computer via USB). For using 2 sets of headphones you could get a "Y" adapter, but both headphones would have the same volume. The Scarlett 2i6 has 2 separate headphone out jacks.
Link to 2i4: https://us.focusrite.com/usb-audio-i...s/scarlett-2i4 I haven't used any of these (still using my trusty Digi002 rack and Command 8), but have seen them recommended quite a bit for an inexpensive interface. Per the website in the link I provided, the Scarlett now comes with ProTools First, and works with PC and Mac.
Thanks for the advice, which led me to the Focusrite iTrack Dock. Never heard of this device. It seems to fit my needs quite nicely, even with a single headset output.
However, based on what I've read so far, the Axiom (has both 5-pin MIDI I/O and USB connector) doesn't seem to be compatible. I have to do some more research.
Wow, that is quite a device. I had never heard of it either. Where do you see that the Axiom is not compatible? On the Technical Specs tab for the itrack dock, the Axiom is not listed as having been tested, but it is not on the Known Incompatible list. I would think midi is midi. Does you Axiom have it's own power supply? I could see an issue if it relies on USB power, and maybe the iTrack doesn't output enough power.
IK Multimedia iRig woks great with our ipads and use that little gadget quite often when on airplanes and hotels. Cheap too
Doesn't have midi but works with audio in and out atleast and does a great job with sound quality. We use Synthmaster as a VI aswell as Propellerheads VI. http://www.ikmultimedia.com/products/irighd/ Here are a few other units that works with ipad: http://www.sweetwater.com/c1058--iPad_iPhone_Interfaces
I do not have a power supply for the keyboard, but it is an option. Quote:
Alesis were about the first to market with an ipad dock - I'm not certain if they still make one, but it was pretty decent, and had MIDI sockets, as well as Mic pre's.
Behringer make (or made) a clone of the Alesis unit, which also has MIDI sockets, for a fraction of the cost of the Alesis - though I've no idea how good / bad it is (I get the impression that, these days, Behringer are better than their old reputation would have people believe). In either case, I'm sure the pre's on the Focusrite would be far superior, but considering MIDI seems to be your priority, I'm sure either units shortcomings would be tolerable, given your goal. |
Thanks a lot, Carl.
Yeah, it seems that the Focusrite pre's are the same as in the Scarlett series, and I'd have no problems with that. I see that both Behringer and Alesis have some alternatives. Gut feeling; I'd go with the Behringer over the Alesis. A friend of mine bought the iTrack a while back (without telling me, dang it), so I can test it in combo with my Axiom keyboard.
PT is actually great for songwriting | Chingy | Pro Tools 10 | 31 | 01-02-2012 08:56 AM |
songwriting software for mac | Bender | General Discussion | 0 | 02-28-2011 11:53 AM |
OT: songwriting splits... | billy101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-08-2003 02:15 AM |
songwriting process | stut5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 11-27-2002 05:49 AM |
For Songwriting Rig: PT ver 5, 001, or DP??? | Woodboy | Tips & Tricks | 2 | 01-30-2000 01:00 PM |
